Hi!
I am restoring a Honda CB 550 K3 (built in 1977 for the European market) and have a few questions about the Keyster PD 46A carburetor. Although I have red most of the relevant posts here, I did not find answers to those questions and I hope you can help.
First question: The installed emulsion tube has a slightly different arrangement of holes than the one included with the Keyster gasket set. See attached photo. I would simply continue to use the existing emulsion tube. What do you think?
Second question: The choke flaps were previously screwed to the choke rod with the familiar hollow screws (to prevent them from loosening due to vibration). I would replace the screws with stainless steel screws with a spring washer for security, or is there any reason not to?
Third question: My carburetor was missing the part that can be seen in the attached drawing (highlighted in yellow). However, my carburetor seems to be slightly different anyway, because my two choke rods are one connected piece, while those in the illustration are connected with small plastic brackets (highlighted in red). I'm not sure what the function of yellow part is, and since it wasn't present on my carburetor anyway, I would just leave it out. Does this makes sense?
Thanks,
Julius
