Author Topic: Original Koni 76P-1413  (Read 864 times)
Offline BenelliSEI
  • 1969 cb750
« on: July 31, 2025, 12:55:07 PM »
I bought these ages ago and they disappeared in my shop. I had them packaged up nicely, standing in the corner of a shelf and stumbled on them today. Clearly stamped 76P-1413.
Took one apart and adjusted it right down (fully compressed, with spring removed, and rotated the shaft fully counter clockwise). Spotless shaft, no leaks and works perfectly! 14.3 inches (fully extended, eye to eye), they seem a match for the new IKON 7610-1413.
The black painted springs have no chips or corrosion and the shock bodies are unmarked. Seem to have very little use. Maybe none?
« Last Edit: July 31, 2025, 01:04:12 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
Re: Original Koni 76P-1413
« Reply #1 on: July 31, 2025, 12:56:39 PM »
Pondered how to dismantle them for a while. None of my spring compressors would grab the bottom of the spring without marring the shock body. Set up a ratchet strap and had it apart in a few minutes! Unloaded the strap one click at a time…..
« Last Edit: July 31, 2025, 01:05:33 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: July 31, 2025, 01:01:51 PM »
Anyone have a set of these on their cb750? Thinking of trying them on my 1971 cb750K1. How many turns did you run up the rebound setting?
Online newday777
« Reply #3 on: July 31, 2025, 01:08:32 PM »
They are too long for the SOHC Fours
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: July 31, 2025, 01:18:32 PM »
Stu….. they only appear to be +1/2” vs. the ones on my K1?  Looks like they were originally for the later cb750F or twin shock CBX1000.
« Last Edit: July 31, 2025, 01:31:34 PM by BenelliSEI »
Online newday777
« Reply #5 on: July 31, 2025, 02:57:18 PM »
My K5, K6 K8 and F3(78) are all 13.25" center to center of the bolts
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: August 01, 2025, 06:17:10 AM »
Stu….. I suspect mine are too. Thinking about it last night, I might try a slightly lower spring on the Koni (I have a few sets) and see if I can get them down an inch?
They are in excellent shape and look so good!
« Reply #7 on: August 01, 2025, 12:56:04 PM »
Shorter spring may well leave the retaining collets loose, only safe way would be to shorten the damper rod
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: August 01, 2025, 05:32:14 PM »
Agreed….. If I can’t get a softer set and make them a snug fit with the preload adjustment, it’s not on.
