Author Topic: CB400 Master Cylinder Coating  (Read 397 times)
Offline grumpy56
« on: August 12, 2025, 06:55:28 PM »
What is this purple-ish coating on my master cylinder and mount? What have you all used to re-coat it as mine is quite scratched up for some unknown reason. Thanks.
Re: CB400 Master Cylinder Coating
« Reply #1 on: August 12, 2025, 07:22:14 PM »
It's anodized.  It was originally black.  Ultra violet radiation(the sun) has` made it fade
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #2 on: August 12, 2025, 08:07:57 PM »
You can sand and clean very thoroughly and use one thin coat of Satin Black Epoxy Primer.
It will look too black. Not many people will notice the difference. Epoxy primer is what I use on engine compartments and is resistant to brake fluid,oils, gasoline.
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #3 on: August 12, 2025, 10:25:50 PM »
Epoxy primer is also not UV resistant and will turn gray out in the sunlight.
