Author Topic: To Paint or to Polish  (Read 1473 times)
Offline paul_nz
« on: August 26, 2025, 08:49:07 PM »
I am sure that this question has been asked before, and I am wondering what best option is to refinish oxidised aluminium on my bike 72 CB750. Do I soda blast then polish, or soda blast and paint/clear coat?
I recall seeing articles many years ago re the aluminium being a paint finish??
Your help most appreciated
Online newday777
Re: To Paint or to Polish
« Reply #1 on: August 26, 2025, 09:46:42 PM »
The engine cases were painted from the factory.
The engine side and cam covers were polished and then clear coated.
« Reply #2 on: August 27, 2025, 09:36:11 AM »
If your side covers have become hazy, I've had some good luck with Simichrome polish. It ain't cheap (comes from Germany), but it doesn't take much of it to work (except elbow grease) and it seals the covers against any further oxidation. I did mine (and my front forks) in 1978 and they still look the same, shiny parts they were then. They had already corroded then, due to my intense use of the bike in those days (with little/no maintenance, I was a bad boy...).
Offline paul_nz
« Reply #3 on: August 28, 2025, 12:41:41 PM »
Thank you, i will look at availability of simichrome
Offline Rayzerman
« Reply #4 on: August 28, 2025, 12:52:05 PM »
Just went through the same questions on what to do with my 350F covers... had them bead blasted, so was intending to polish... the blasting process revealed pitting and other flaws in the aluminum in the wrong places... on top and visible.  I would say soda blasting would be safer, I had no such person around here.
Started sanding.... lotta work to get them down to polishing grit stage.  Abandoned the idea since the flaws were too deep.  So I bought Duplicolor Chrome paint, experimented then cleared.  The Chrome paint seems very high in aluminum, doesn't dry true gloss... I cleared over it and it mellows it out.  Looks nice and clean but doesn't look polished.  When done is slightly different than Honda Cloud Silver, and I wasn't looking to match it to the engine (which I purposely did not clear).  I did my forks with this, perfectly acceptable to me for my purposes.  The paint solution is less maintenance.  IF you look at the front caliper bracket, it is virtually the identical look, and it was cleared from the factory but I don't know how the aluminum was treated under... not polished for sure.  That was my inspiration and the fork/brake parts are the same, painted those same time.
My next experiment would be..... soda blast, sand down to 1000-2000 grit, kinda polish with 0000 steel wool at least uniform all over.  This may leave enough roughness for clearcoat to stick.  I had polished a part earlier to like chrome..... clear will not stick well... if anything go 2K clear and it may harden on there but methinks better to have some roughness to stick to.
You just need to decide for yourself how you want it to look and experiment a bit on some metal coupons.
« Last Edit: August 28, 2025, 12:58:12 PM by Rayzerman »
« Reply #5 on: August 28, 2025, 01:41:14 PM »
On my last project I had all the engines covers and fork legs vapour blasted before polishing began. Well worth the extra step.
« Reply #6 on: August 29, 2025, 07:40:24 AM »
I hand polished and cleared, the cases were painted
Offline paul_nz
« Reply #7 on: August 29, 2025, 09:46:47 PM »
Thank you all for your comments, after lots of elbow grease, the engine covers are looking awesome, i am not chasing perfection as the bike has never been restored, i just want it looking "tidy" so to speak
Great forum with plenty of topics to review, we never stop learning, thanks to those who contribute.
« Reply #8 on: August 30, 2025, 07:48:24 AM »
One thing to consider about painting and clear coating. I live on Maui which of course has a marine environment. Finishing decisions here have to take into consideration what the salt air will do which is why I have stainless spokes, clear coat, etc. Others that live in more arid areas don't necessarily need to take that into consideration.
« Reply #9 on: September 02, 2025, 07:31:37 AM »
On my last project I had all the engines covers vapour blasted
+1, vapor is an awesome process for bare aluminum.  I'm currently having some valve covers done.
« Reply #10 on: September 02, 2025, 10:28:47 AM »
I'm tempted to set up a vapor tool.
Offline la ca fe
« Reply #11 on: September 07, 2025, 09:56:05 AM »
A polishing wheel does wonders.
1976 cb750k
1976 cb750f
1975 cb750f
1970 cb750
1977 xs750
Online TideWater2
« Reply #12 on: October 23, 2025, 07:08:05 AM »
I tried something new and I'm still undecided on how effective it was. I dry ice blasted this engine. I went this route because I was not going to open this engine up and was advised by the vapor blast guys that media would get inside no matter how well it was sealed. PO had painted the fins black so that is a PIA. I have to read up on polishing. I'll post before and after pics.
3 - 1971 CB750 K1s
« Reply #13 on: October 23, 2025, 07:23:17 AM »
How you considered removing just the engine covers and having them vapor blasted? [instead of polishing] You could then paint the rest of the motor.
« Reply #14 on: October 23, 2025, 07:39:05 AM »
Depending on the desired outcome, making a corroded engine look nice without some disassembly is pretty tough
Online TideWater2
« Reply #15 on: October 23, 2025, 08:23:26 AM »
After.
3 - 1971 CB750 K1s
Online TideWater2
« Reply #16 on: October 23, 2025, 08:25:31 AM »
Yes, I will remove the covers and blast/polish them and then paint the engine without covers. I wasn't going to pull the engine completing down.
3 - 1971 CB750 K1s
