Author Topic: 400/4 coil data  (Read 433 times)
Offline MDW
  • 1975 Honda 400 Four Super Sport
400/4 coil data
« on: August 30, 2025, 01:29:33 PM »
Can someone tell me what the primary and secondary ohms/resistance should be for the coils? I replaced both last year with David Silver supplied original manufacturer versions. I wouldn't normally expect them to be bad but I have virtually eliminated all other reasons why cylinders 1& 4 aren't firing. Thanks
Online scottly
Re: 400/4 coil data
« Reply #1 on: August 30, 2025, 05:34:20 PM »
The primary should be about 5 ohms, and the secondary should be about 14K ohms +/- without the plug caps. You could try swapping the blue and yellow wires and see if the problem moves to 2&3. If it does, your problem is not the coil. Don't try to start it, just check for spark.
Offline MDW
Re: 400/4 coil data
« Reply #2 on: September 01, 2025, 05:48:00 AM »
Great thanks. I couldn't find the ohms rating anywhere!
Offline Bodi
Re: 400/4 coil data
« Reply #3 on: September 01, 2025, 07:19:40 PM »
They should be 5 Ohms (won't measure 5 ohms but close, this is an impedance not resistance). There are 3 Ohm coils that the 400F alternator won't keep up with but DSS would not make that mistake.
  • I'm back
Re: 400/4 coil data
« Reply #4 on: September 02, 2025, 12:30:51 AM »
They should be 5 Ohms (won't measure 5 ohms but close, this is an impedance not resistance). [...]
Can you explain the difference to us?
Offline Jan187
  • only drugs will eat brains faster than zombies
Re: 400/4 coil data
« Reply #5 on: September 02, 2025, 01:14:25 AM »
Impedance is more or less: how the load under AC currents is seen as a resistance, also expressed in ohms.
Complex indeed :P , will vary per frequency, and other conditions.
Offline Bodi
Re: 400/4 coil data
« Reply #6 on: September 02, 2025, 04:48:40 PM »
AC theory is not for the timid. Best to just accept that DC resistance and AC impedance are different in anything except a pure resistive load.
