Author Topic: 1977 CB550K Electrical Pulse  (Read 685 times)
Offline cr0issqnt
« on: September 22, 2025, 08:44:15 PM »
I am doing a custom build on my 1977 CB550K and the Aftermarket LED tail light I got hasn't worked quite right since I got it. I have narrowed the problem down to a pulsing signal coming from the red wire on the ignition key switch. Is this pulse normal and what are your thoughts on how to make what I have work?
I should specify the brake light and the running light dont work the running light kind of flickers/flashes and the brake light just doesn't turn on at all
« Last Edit: September 22, 2025, 09:07:31 PM by cr0issqnt »
Re: 1977 CB550K Electrical Pulse
« Reply #1 on: September 22, 2025, 10:31:30 PM »
Try a jumper ground wire to your light first to rule out a bad ground.  A good ground is necessary for the LED to work properly.
« Reply #2 on: September 23, 2025, 08:06:13 AM »
No it shouldnt pulse it should be at battery voltage
Offline cr0issqnt
« Reply #3 on: September 23, 2025, 01:49:22 PM »
I had it charging over night and the problem sorted itself out so it might have been just a low battery but I'm not 100% convinced so I will update if anything changes. I'm kind of embarrassed I didn't think to charge the battery first.
« Reply #4 on: September 23, 2025, 03:38:28 PM »
The OEM voltage regulator will 'pulse' ON-OFF-ON-OFF if the battery is marginally low, like 11.6 volts: when it does this the voltage jumps up/down by about 0.8 volt or so. A regular incandescent lamp won't change much with this small voltage toggle, but an LED that is near it's lower voltage threshold certainly will: you see it sometimes in older cars that have changed to LED lights, too. We just had a vintage car show here, and a couple of the guys who are excellent at body and paint work, but not so much with electrical stuff, had this very conversation this past weekend. ;)
