Author Topic: Can you lock up the rear brake on a 550?  (Read 3137 times)
Re: Can you lock up the rear brake on a 550?
« Reply #25 on: October 14, 2025, 03:34:52 PM »
You are welcome, only been working on Hondas for 50 yrs
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #26 on: October 14, 2025, 04:00:28 PM »
This is great information.  I learn new stuff on this forum just about everyday.
Its great when there is closure on threads like this with the solution.
 A lot if times they are open ended.
It makes sense to tighten the axle nut like this everytime. They all sag a little bit. Nice to get it centered.
« Last Edit: October 14, 2025, 04:02:31 PM by Ozzybud »
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #27 on: October 16, 2025, 09:31:26 AM »
+1...good info.  Have not encountered this issue before....
Online denward17
« Reply #28 on: October 16, 2025, 09:46:19 AM »
^It helps to have another bike to ride from the same era to compare to.
The 750 has good rear brakes, and I knew something wasn't quite up to par with the 550.
« Reply #29 on: October 16, 2025, 10:35:06 AM »
Its a bit like the old car drum brakes, after fitting stand on the pedal HARD to centralise shoes , then use adjusters
