Author Topic: Honda CB750 valve cover dilemma  (Read 4891 times)
Re: Honda CB750 valve cover dilemma
« Reply #25 on: October 05, 2025, 08:13:59 AM »
Buffing is somewhat tedious but it's sort of a meditation. I assembled a few tools to help me. I got a set of tiny buffing wheels for a small grinder like a Dremel tool, some mounted buffing wheels for a 6" bench grinder and a slightly smaller buffer my wife used for jewelry. I also bought some scotch bright type mounted wheels in different roughness. All in all, quite a few hours but it worked out.
Offline kyle750
« Reply #26 on: October 05, 2025, 06:51:46 PM »
^ ^ ^ Love the Setup ^ ^ ^   Very nice equipment and well organized work area.  I am envious as I would love to take those machines for a spin.  It really does look like good fun and I could see how the polishing and buffing would be relaxing and meditative.  Seeing the transformation from rough dull aluminum to polished must be very enjoyable and rewarding.  Thanks for posting the photo!
« Reply #27 on: October 06, 2025, 07:06:38 AM »
4.  Chrome plated
  Aluminum is a wonderful metal  - why cover it up with chrome?
Back in the day when plating was very popular and inexpensive, guys would chrome everything!
But, "Chrome won't get you Home"!
Offline kyle750
« Reply #28 on: October 06, 2025, 07:18:56 AM »
A good adage and reminder to set priorities.    Today I worked on ensuring the mechanical reliability of the front brakes rather than the finish of a valve cover  ;) Thanks!
« Reply #29 on: October 06, 2025, 07:19:23 AM »
Thank you, behind the piece of cardboard is a window, I have a fan in it that creates a flow to the outside, helps with whatever is in the air. I usually sand small wood projects on that table, handy to have additional protection and keep the general work area a little cleaner.
Offline Mikey G.
« Reply #30 on: October 06, 2025, 11:40:41 AM »
There's a LOT of jobs on these bikes I dread, I put off, and I avoid at all costs.  By contrast, buffing and polishing parts is downright therapeutic.  I found an old cheap bench grinder, put two wheels on it (hard and soft), then run a rough polishing compound on one, a fine compound on the other, and go to town.  It doesn't take much to make parts look really good, and aluminum parts without clear will hold up quite nicely for a number of years before needing addressed.
My advice?  Grab a cheap decent valve cover, sand off the clear coat, and buff it to as shiny a finish as you want.  Pretty soon you'll be polishing every piece of aluminum you have.   ;)
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
Online Don R
« Reply #31 on: October 06, 2025, 11:47:04 AM »
 I took a few CB750 pieces to have the chrome removed at the shop that probably did them to begin with. The owner said that he tries to discourage the Harley guys that come in from chroming their aluminum, probably because he opened a polishing shop in their old competitors building across the street.
 He will do it if they insist.
Offline kyle750
« Reply #32 on: October 06, 2025, 06:41:05 PM »
This comment has been a wake up call for me  :o
Another wake up call and very true with me.  I am not mechanically inclined (but learning) so it's much easier for me to work on the cosmetics.  If the bike is not up and running well then the look of the valve cover has no meaning and serves no purpose.
A real eye-opener and perhaps poking the bear has awakened my slumber! Thank You Gentlemen!
Offline M 750K6
« Reply #33 on: October 07, 2025, 05:46:46 AM »
I had no choice, this is how mine came, leaked like a sieve:
Offline M 750K6
« Reply #34 on: October 07, 2025, 05:49:41 AM »
Not a great shot, but all fixed with an eBay replacement. I bought a buffing wheel which I bolted onto my bench grinder and finished by hand. I enjoy polishing it every couple of months.
Offline kyle750
« Reply #35 on: October 07, 2025, 06:29:33 AM »
^ ^ ^ Beautiful Work ^ ^ ^  Without a good seal a replacement valve cover was a mechanical neccesity and not a cosmetic option. Going to the additional effort of buffing the cover and making it look nice is an extra special bonus. It turned out looking fantastic  :) An excellent balance between working well and looking good.
Offline Kelly E
  • Geriatric Hooligan
« Reply #36 on: October 07, 2025, 02:23:08 PM »
Instead of sanding off the original clear coat I strip it with old brake fluid. An overnight soak and the clear coat scrubs right off with an old toothbrush. It saves a bunch of elbow grease and sandpaper.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
