Support the site. Your contributions keep this site running.
Quote from: Deltarider on October 17, 2025, 07:47:32 AM[...]Quote from: papi_sosaa on October 17, 2025, 07:15:17 AM[...] I ordered this Ignition coil kit from 4into1 and I'm just curious about resistance.https://4into1.com/ignition-coils-caps-and-wire-honda-cb650-gl1100-1200/Quote from: Deltarider on October 17, 2025, 07:47:32 AMThat set of coils would also be my choice.As a matter of fact: that set looks ideal also for CB Fours with conventional breakerpoints ignition. Just add a 2 Ohm ballast resistor in the primary route. I favour screw on connections like these coils have. I can't comment on the quality of these particular coils though.
Quote from: papi_sosaa on October 17, 2025, 07:05:52 PMQuote from: scottly on October 17, 2025, 07:02:11 PMReplace the plug in any case. BTW, did the hole in the old cap look like it had burned through from the arcing, and was it in the same location as the arcing now?I'll run over to my parts store tomorrow and grab some new plugs.I believe the arcing is in the same place however the old cap looks like it got chipped rather than burned.well that cap is #$%*ed for a start.
Forget Clymer, you need the specs from a genuine Honda manual
Quote from: Deltarider on October 17, 2025, 11:12:48 PMQuote from: Deltarider on October 17, 2025, 07:47:32 AM[...]Quote from: papi_sosaa on October 17, 2025, 07:15:17 AM[...] I ordered this Ignition coil kit from 4into1 and I'm just curious about resistance.https://4into1.com/ignition-coils-caps-and-wire-honda-cb650-gl1100-1200/Quote from: Deltarider on October 17, 2025, 07:47:32 AMThat set of coils would also be my choice.As a matter of fact: that set looks ideal also for CB Fours with conventional breakerpoints ignition. Just add a 2 Ohm ballast resistor in the primary route. I favour screw on connections like these coils have. I can't comment on the quality of these particular coils though.I don't think my coils are bad, I don't trust the Chinese quality coils and I do have a spare set of OEM ones if my current OEMs are actually bad.Quote from: dave500 on October 17, 2025, 11:41:28 PMQuote from: papi_sosaa on October 17, 2025, 07:05:52 PMQuote from: scottly on October 17, 2025, 07:02:11 PMReplace the plug in any case. BTW, did the hole in the old cap look like it had burned through from the arcing, and was it in the same location as the arcing now?I'll run over to my parts store tomorrow and grab some new plugs.I believe the arcing is in the same place however the old cap looks like it got chipped rather than burned.well that cap is #$%*ed for a start.That's the old cap, it's still arcing with the new cap.Quote from: bryanj on October 18, 2025, 02:48:03 AMForget Clymer, you need the specs from a genuine Honda manualI've been making due with the Clymer but I'll see if I can find one.
Quote from: papi_sosaa on October 18, 2025, 09:22:52 AMQuote from: bryanj on October 18, 2025, 02:48:03 AMForget Clymer, you need the specs from a genuine Honda manualI've been making due with the Clymer but I'll see if I can find one.The honda manuals are on here in pdf format
Quote from: scottly on October 17, 2025, 07:02:11 PMReplace the plug in any case. I'll run over to my parts store tomorrow and grab some new plugs.
Quote from: papi_sosaa on October 17, 2025, 07:05:52 PMQuote from: scottly on October 17, 2025, 07:02:11 PMReplace the plug in any case. I'll run over to my parts store tomorrow and grab some new plugs.Any updates???
