Would be a cool project to restore as a period correct racer!
I have a small fairing sitting around if you are interested?
Thank Steve-o. I'll keep the fairing in mind if I move this project forward. My mind wants to build it as a wheelie bar bike. I really want to see if I can launch an SOHC based bar bike hard enough to get a low 1.30 to high 1.20 second 60' time. I'd like to see a 5.9xx 1/8th mile ET on raw horsepower as a target. I know a little nitrous oxide would make that number easily attainable. The bike would need to be as light as possible so using light weight wheels and a 530 chain is important. I'd prefer to use the stock body work but that does add weight. I may be on the hunt for a tank with a rusted bottom and just gut it out as a shell. I've got an aluminum fuel cell is could then use. That's how my mono shock bike is set up now. A backbone fuel cell would be more ideal and something to consider also. It'd be great if i could find a one piece Tracy body for a period correct look though.
I've got a mildly ported K head on hand already along with set of 72mm MTC pistons. I'd send that head off to get oversized valves installed and a bit more port work to make it breath. I don't currently have a bored cylinder and would have to acquire a used one or get a stock block reserved and bored. Someplace in my stash there's an RC315 cam though I'd much rather have a 327 cam. I know that cam works well as I have one in both of my dragbikes now. Connecting rods would be my next shortcoming to overcome. Upgraded rod bolts with stock rods might be something to ponder in lieu of aftermarket parts. My local guy is no longer able to get in the shop to work so I'd have to find someone to undercut the transmission without shelling out a fortune. As far as a clutch setup goes, I do have an MRE lockup that can be installed. I've got numerous choices to pursue for ignition controllers. MSD, Pro Series 2, Dyna 4000 or just a simple DRL400 with a dynamic S plate. I'm sure I have a set of coils on a shelf in the shop so spark is pretty much covered. Carburetors are going to be an issue unless I buy new RS 34's. Of course they aren't free and would likely be my biggest expense on the build besides a new set of custom built wheelie bars. Its the material cost that'll hit me in the head. Labor won't be much because I have a good friend that'll hook me up. He's already done several sets for our KZ based dragbikes and and very satisfied with his work.
I've got the off season to make some decisions and collect more parts if I want to bring this old drsgbike back to life. Oh, and I'll graciously accept items from my friends here on the forum to make this resurrection happen😅🤣😂
