Author Topic: Tachometer renewing  (Read 722 times)
Offline mikerider
Tachometer renewing
« on: November 04, 2025, 06:33:16 PM »
Couldn't one take a tachometer and drill a hole in the side of it and sray in alittle PB blaster to lube it up alittle?  Some say they become dry from sitting,  just wondered if this wouldn't help.
Sent from my SM-S926U using Tapatalk
Re: Tachometer renewing
« Reply #1 on: November 04, 2025, 07:10:34 PM »
The drive inside is a tiny mag-slip clutch gizmo. I've sometimes found that what they need is to be run for a while, then they work again. They buzz, vibrate, the needle jitters, and then suddenly they just...work! This seems to be getting more common from bikes being found sitting for 20+ years, unused.
« Reply #2 on: November 04, 2025, 08:58:25 PM »
  If you WD40 the cable, the WD will climb all the way to the needle and stain the gauge face. I'd imagine something similar with a lube spray.
Offline Dr. Frankenstein
« Reply #3 on: November 05, 2025, 03:32:30 AM »
Kind of related, but I just revived a KZ400H tachometer; it was so stuck it snapped the tach cable. I was going to open up the gauge itself somehow but then got the idea to just apply some heat to the drive and was able to get it turning again; I assume it was gummed up somehow from sitting for over 20 years.
I cut a length of the broken wire off the end that had the tachometer drive on it, chucked it up in my power drill and heated the cable drive on the back of the tach where the wire goes in to free it up. I put the cable in the tach and spun it up with the drill (it spins to the left, in case anyone is wondering) and squirted a little Kroil and PB Blaster in there to help it spin, and I have my tach back!  :D
Offline Kelly E
  • Geriatric Hooligan
« Reply #4 on: November 05, 2025, 08:44:49 AM »
Watch out with the PB Blaster, it gets sticky when it dries out. I use it to install handgrips. They slide on easily and the next day they are stuck on good.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #5 on: November 05, 2025, 10:27:02 AM »
Huh - good to know. I'll be sure to check it again before I put the new cable in.
« Reply #6 on: November 05, 2025, 05:42:33 PM »
Good to know, thanks! I just bought some.
Offline mikerider
« Reply #7 on: November 17, 2025, 05:56:07 AM »
how about WD-40?
