Author Topic: Cb750k1 airbox  (Read 362 times)
Offline Remcod
Cb750k1 airbox
« on: December 02, 2025, 04:58:50 AM »
Im going to pickup bits of a cb750 k1. How do i recognise a k1 airbox? I believe the air intake is bigger, but what is the size? Any other id marks?
Thanks,
Remco
Verstuurd vanaf mijn SM-A566B met Tapatalk
Offline lash
Re: Cb750k1 airbox
« Reply #1 on: December 02, 2025, 05:04:23 AM »
Same airbox from 71 to at least 76
Re: Cb750k1 airbox
« Reply #2 on: December 02, 2025, 05:24:10 AM »
71 K1 airbox has bigger air inflow openings than the K2-K6 have(more restriction for the different cam)
Offline Remcod
Re: Cb750k1 airbox
« Reply #3 on: December 02, 2025, 05:39:16 AM »
Yes, but what size is the opening?
Re: Cb750k1 airbox
« Reply #4 on: December 02, 2025, 09:41:06 AM »
I was saying that to Lash.
I can't find my K1 airbox at the moment to measure it. All I could find is a K2-K6
Offline Oly
Re: Cb750k1 airbox
« Reply #5 on: December 02, 2025, 01:14:05 PM »
The two openings measure 3.97 " X 0.50 ".
One of the openings has a flared Lip opening making it look wider but the internal throat of the openings are the same.
These pictures are off my CB750 K1 manufactured 8/70 and is original equipment.
1971 CB750 K1
1967 BSA 441 Victor
1966 Yamaha 250cc YDS3c Big Bear Scrambler
Online HondaMan
Re: Cb750k1 airbox
« Reply #6 on: December 02, 2025, 05:10:18 PM »
The inner 'wall' of the slot openings in the K1 airboxes are lower than in the later ones by about 1cm. This 'closed upward' in the K2 versions to be only as wide as the curved outer section.
You can (and I often have) lower the inside 'wall' of the opening to be that same 1cm lower opening. It just takes a sharp blade. Be aware that if you're riding behind a big fairing (like a Vetter) this will increase engine noise slightly above 3000 RPM, though.
« Last Edit: December 02, 2025, 05:11:56 PM by HondaMan »
Offline Remcod
Re: Cb750k1 airbox
« Reply #7 on: December 02, 2025, 11:13:00 PM »
Thanks all, very helpful!
Re: Cb750k1 airbox
« Reply #8 on: December 03, 2025, 06:31:09 AM »
Great….. Learned something today!
Offline Rookster
Re: Cb750k1 airbox
« Reply #9 on: December 05, 2025, 12:07:53 PM »
The K1 airbox also does not have the embossed lettering CB750F on the side.
Scott
Online HondaMan
Re: Cb750k1 airbox
« Reply #10 on: December 15, 2025, 07:33:08 PM »
Scott
This is partly true: the Old Factory K1 did not have them, while the New Factory bikes did after about 3/1970. In the early days of these bikes, this was a 'quick check' to see which version of the K1 was in front of you. ;)
Offline Remcod
Re: Cb750k1 airbox
« Reply #11 on: December 16, 2025, 12:03:00 PM »
Oh dear. Different versions of K1. I am a originallity fetishist. You should not tell me those things. Have mercy
