hello all! newbie
was going thru carbs and found tiny o-rings
in ultrasonic cleaner.
question: under the pilot screw, is there a washer and an oring that's sits into the carb ?
in each kit, there are 3 of the same size. one for pilot screw, one for bowl drain plug and don't know where 3 rd one may go.
TIA !!
on another note, the vac tee's were not available so I carved them from a black bungee cord end( .556 thou exactly) then used a heated rod to melt the one hole in the top.
Cheers< Dennis
