It seems Honda put a gob of weld at the end of the 6mm bolts, correct? Does one’ grind off these with say a dremel? Otherwise they break & have to be drilled out & tapped which doesn’t always work out so well! Parts book just says 6x12mm, I would think chrome not zinc…?
