Author Topic: Having Fun with a Honda CB550 Master Cylinder  (Read 31596 times)
Offline kyle750
Re: Having Fun with a Honda CB550 Master Cylinder
« Reply #50 on: December 18, 2025, 03:30:38 AM »
80, 220, 400, 600
Brake lever was only lightly polished
« Last Edit: December 18, 2025, 05:15:42 AM by kyle750 »
Offline kyle750
« Reply #51 on: December 18, 2025, 11:16:31 PM »
Success with the front brake  :)
Excellent pressure with the rebuilt master cylinder.  New piston and piston seal in the caliper working correctly
Took a little time to adjust the brake caliper mount bracket but finally got it set correctly. No movement in the bracket -  solid and tight with no play
Rotor is good - no pulsating or vibrating
Excellent lever response, brake grabs immediately and evenly, and releases smoothly with no drag
« Last Edit: December 19, 2025, 03:52:51 AM by kyle750 »
Offline BenelliSEI
  • 1969 cb750
« Reply #52 on: December 19, 2025, 06:29:09 AM »
That looks great. Did you clear coat?
Offline kyle750
« Reply #53 on: December 19, 2025, 06:39:29 AM »
Sanded and light polish with autosol to try to seal the aluminum.   I don't think paint or clear coat would hold up around brake fluid.  I understand there is special paint for brake calipers but I have not seen it for sale here in Thailand.
« Reply #54 on: December 19, 2025, 07:10:38 AM »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #55 on: December 19, 2025, 07:35:03 AM »
I don't think many paints hold up to brake fluid, that's probably why they anodized them originally
1973 CB 750 K3
10/72 build Z1 Kawasaki
