Looks all correctly installed. I’m a big fan of Mity-Vac brake bleeding tool, but you can also bleed just using a hose on the bleed nipples. Assume you know the sequence?
Pump, pump, pump, hold. Open bleed screw, close bleed screw. Release lever. Wait a few seconds, and repeat, over and over.
