Author Topic: front wheel spacing problem  (Read 289 times)
Offline crashmaster
  • 1972 CB 750 K2
« on: February 08, 2026, 03:29:38 PM »
I attached some pics. 1972 CB750K2. I removed the forks to clean them up, etc. Disassembled the hub and disk, etc. Upon reinstalling the front wheel, I have a large gap where the fork should ride on the axle on the right side. Took the wheel off and tried again - no luck. I don't think anything is bent cuz it was fine before I took it apart. One of the pics shows the caliper, and the inner pad seems out too far? I did not mess with that, but isn't that one stationary anyway? Could use some help. I am stumped. 5 pics attached. Thanks
« Last Edit: February 08, 2026, 03:31:48 PM by crashmaster »
Re: front wheel spacing problem
« Reply #1 on: February 08, 2026, 03:55:55 PM »
Do you have the spacer that goes between the axle nut and the bearing installed?
Offline crashmaster
  • 1972 CB 750 K2
« Reply #2 on: February 08, 2026, 03:59:41 PM »
Scott - yes, it's in. I just loosened the triple tree clamps and twisted the forks a bit, and it seems like that may be the fix. Maybe they are a bit bent.
« Reply #3 on: February 08, 2026, 04:04:41 PM »
Bent forks would have been my next guess.
Offline crashmaster
  • 1972 CB 750 K2
« Reply #4 on: February 08, 2026, 08:57:26 PM »
Is there a proper sequence to tightening up the fork clamps? Or unusual torque settings? I do have the D washers in the upper clamps
