Author Topic: Got me a broken side cover  (Read 13625 times)
Offline Gregorymoto
  • SOHC Aficionado
Re: Got me a broken side cover
« Reply #25 on: April 07, 2008, 05:42:42 PM »
There is no JB on the inside or outside, only on and in the crack. I basically do the same as you do with the Glue and Soda.
As far as strength, the pic listed is my tail section on my racer that was broken when some ass tried to move my bike to give him a better space for parking. It gets allot of vibrational force not to mention that it is the part that my poor girlfriend sits on when i need to pick her up from work.
It is solid and good as new.
Check it out when you get home.
Have a good one.
G. Mountain
Yep, i have issues with this sort of stuff.
Offline gar
  • '75 CB550
« Reply #26 on: April 23, 2008, 07:05:24 PM »
ONE vote for Terry's method.  The bottom snap-in fastener and a half-dollar-sized piece of sidecover had broken when I pulled it off to remove the battery for the winter.   I did as he wrote -  used a rotary tool to bevel the edges so a V would form, taped the broken part in place, filled the V with baking soda, and dropped liquid Superglue onto the baking soda.  It saturated and solidified the baking soda very rapidly; it was not possible to mix it.  It made a nice semi-opaque filler that seems to have made a very good bond.  Time will tell how it holds up, but it looks very good -- you can hardly see the crack from the outside of the cover-- and it'll be back in use tomorrow.
Don't use a big word where a diminutive one will suffice.
Online Terry in Australia
« Reply #27 on: April 23, 2008, 07:09:33 PM »
Good to see mate, I'm glad I was able to help. Cheers, Terry. ;D
Offline 74cb750
« Reply #28 on: May 08, 2008, 03:22:32 AM »
Hope the baking soda and super glue work, as I'm about to try in on my 74 cb750 sidecover.  ???
peace,
michel
Laugh at least once a day.
Life  $ucks, then you die.
« Reply #29 on: May 08, 2008, 11:41:47 PM »
Use it mate, and you won't be disappointed! Well, no more disappointed than usual, anyway........... ;D
RickyD
« Reply #30 on: May 15, 2008, 02:58:15 AM »
anyone ever try construction adhesive? That stuff bonds anything
troppo
« Reply #31 on: May 15, 2008, 03:10:08 AM »
You ever tried sanding it? No chance, its so rubbery when dried it flexes while you rub your sidecover away
Offline dagersh
    • Photos
« Reply #32 on: May 15, 2008, 11:15:28 AM »
Terry and Greg -
What attachment are you using on the Dremel to V out the crack?
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Gregorymoto
  • SOHC Aficionado
« Reply #33 on: May 15, 2008, 08:42:51 PM »
I use 2 things, the cone shaped stone, and drill bit, the drill bit is good at hi rpm using it to trim off or to get a good shaped angle.  I also use it to key the surface before i start work.
Good luck to you.
G. Mountain
« Reply #34 on: May 16, 2008, 12:45:37 AM »
I haven't tried the stones Gersh, but I've got a couple of little metal burrs for my Dremel knock-off for "V"-ing out the plastic. Cheers, Terry. ;D
Offline dagersh
    • Photos
« Reply #35 on: May 18, 2008, 12:04:26 PM »
Thanks Guys!
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Gregorymoto
  • SOHC Aficionado
« Reply #36 on: May 18, 2008, 01:47:14 PM »
any time man..
