Author Topic: What do they fit?  (Read 1626 times)
sirg
What do they fit?
« on: May 08, 2007, 06:37:54 PM »
Anybody know? They were in a box with some other odd parts.
Offline OldSchool_IsCool
  • Really feeling like an
Re: What do they fit?
« Reply #1 on: May 08, 2007, 06:39:43 PM »
Are there any numbers on the castings?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline twisting_edge
  • 1978 CB550K 12k
« Reply #2 on: May 08, 2007, 06:42:20 PM »
I can rule my bike out: the float bowls are the wrong shape (1978 550k). I assume Honda used pretty much the same float bowls for a number of different models/years. It's a pretty generic part.
Not that the carbs couldn't be made to fit, but they aren't the right part, unless someone's tacked on some even more generic float bowls (which probably wouldn't work too well for obvious reasons).
« Last Edit: May 08, 2007, 06:45:49 PM by twisting_edge »
If life were fair, I'd be dead.
Daves_76_SS
« Reply #3 on: May 08, 2007, 06:57:52 PM »
They look like Mikunis.  They look just like the carbs on my Yamaha.
holdfastgreg
« Reply #4 on: May 08, 2007, 07:56:54 PM »
Mikuni and Weber definitely label their carbs.
sirg
« Reply #5 on: May 20, 2007, 11:39:43 AM »
Carbs are Keihin, they have their mark and i have no clue as to what they came off of.
Offline Patrick
« Reply #6 on: May 20, 2007, 11:52:05 AM »
They look like Mikuni carbs used on vintage Yamahas. Like maybe they are off an Yamaha XS from the early 80s. If they have a big air screw in the neck they are 1979 or early. A small recessed (and likely sealed) air screw is 1980 or later, after EPA regs got tougher.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline tomkimberly
« Reply #7 on: May 20, 2007, 03:39:21 PM »
They are 83 and up Nighthawk carbs, either 650 or 750?
Tom
