Author Topic: DUAL-DISC GUYS - What kinda Splitter/Y-Blocks did you use ?  (Read 5426 times)
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
As the topic states I am looking for options when it comes to splitting front brake lines for a dual-disc setup.
I am sourcing parts to install a dual-disc setup on my CB450, and I am kinda stumped on how I should go about splitting the lines.
Suxs I just spent $45 to get a line made from HEL, but what can I do ? (I could do a double banjo at the master but that would be nasty looking)..
As everything else having to do with this bike I am looking for something that is "light" looking, small, racey, etc...
I have a request out for a factory DOHC CB750 splitter, but I think that might be too big/clunky for this little bike. I have a splitter on my CB750 from a Guzzi, But I cant seem to find another one, and the guy I got that one from is no longer in business.
So (if you would be so kind) post some pics of what you used and let me know where you got it...
As always, any and all help is much appreciated....
* * * Don't forget Mods Vs. Rockers III is less than a month away (6/16/07-Chicago, IL)..* * *
« Last Edit: May 17, 2007, 08:14:33 PM by ProTeal55 »
Offline Soos
Re: DUAL-DISC GUYS - What kinda Splitter/Y-Blocks did you use ?
« Reply #1 on: May 17, 2007, 12:55:16 AM »
I got mine off a 1978? 1979? KZ1000.
I had to make a custom alluminum mount bracket to get it to fit, as the hole spacing is a tad different(about 3/8 off if i rember right)
The hoses sit that way due to me putting a half twist in the cables, looks a bit better than them just sagging there IMO.
Sorry about the quality, it's 2am right now, and I have no light under the carport, so it was shoot, and hope for the best.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Soos
« Reply #2 on: May 17, 2007, 12:57:05 AM »
And yeah it looks a bit big on my front end(i'm assuming you're looking for a smallish splitter), but it helps hide from view the air horn compressor mounted on the bottom of my tripple trees.
l8r
-=≡ Soos ≡=-
Offline Steve F
« Reply #3 on: May 17, 2007, 04:08:34 AM »
Joe,
I just split the lines right at the master cylinder and don't have the "junction" you're talking about.  Two lines directly to the calipers.  Just used a double banjo bolt on the m.c.
Offline Rhonda750F
  • In the Works!
    • Gallery:
« Reply #4 on: May 17, 2007, 07:12:50 AM »
I have 2 other options for you.  If you want some kind of splitter use one from a F2/3 model 750.  I'm sure you could easily find one around here.  Or do what modern sport bikes do.  Both my buddies bikes(gixer and a busa) have one line from the master that runs to the right caliper and a double banjo with the other line running over the fender to the other caliper.
I'll see if I can get a pic so you can better visualize it.
Paul Z.
Paul Z.
1978 CB750 F rolling chassis for sale. PM me.
Offline dagersh
    • Photos
« Reply #5 on: May 17, 2007, 09:36:31 AM »
PT,
My '03 Le Mans has the splitter set up like this as well.  I just really noticed it this weekend when I was out riding.
If you like the Splitter used on your 750 you might want to try:
www.mgcycles.com
www.motointernational.com
Either one of these guys can probably help you find the piece you are looking for.  I would think that with the Guzzi's Integrated brake system, there is no shortage of line splitters.
Hope this helps.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #6 on: May 17, 2007, 06:11:28 PM »
Two options. Splitter is from a 500 Interceptor, and dual lines from the master.
Offline dagersh
    • Photos
« Reply #7 on: May 18, 2007, 11:41:07 AM »
Bwaller,
Those dual lines look great on that front end!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
RSV12K
« Reply #8 on: May 18, 2007, 02:29:36 PM »
I second the idea of running two lines from the master cylinder and not bothering with the splitter. That's a race set up, which is what I think you're looking for. I think it looks good too.
I've also seen set ups on modern sport bikes where you run one line from the MC to first caliper and using a double banjo bolt, run another line over the fender to the second caliper. That way it looks good too.
You probably know this..you'll probably need a banjo switch to trigger the brake light. HEL and lots of other places sell them for $12-$15
Offline sandcastcb750
« Reply #9 on: May 18, 2007, 04:14:34 PM »
Can't you use a longer banjo bolt, put two lines together?
Double discs stop like modern bikes.......you never want to go back to one disc on a CB750 SOHC
Offline ProTeal55
  • Est1968.com
« Reply #10 on: May 18, 2007, 06:12:42 PM »
Thanks for all the good ideas guys, and please keep them coming...
I for one do not dig putting two banjos off the master (just looks like an afterthought to me)..
I def. need to get s splitter, with a single inlet and dual outlets..
The search continues  ;D
Don't forget Mods Vs. Rockers III is less than a month away (6/16/07 / Chicago, IL)..
« Last Edit: May 18, 2007, 06:18:08 PM by ProTeal55 »
Offline Bodi
« Reply #11 on: May 18, 2007, 07:36:59 PM »
You could use a SOHC4 switch block with a double banjo, single line from master to block. I don't remember if the 450 had such a switch unit or used a lever switch.
Can one get a triple banjo bolt? With just crush washers and a crown nut you could join 3 lines and it would look pretty sweet.
The crossover line idea is also good and looks OK if done well but how to bleed it?
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #12 on: May 18, 2007, 08:12:27 PM »
I've just run a dual banjo bolt from the standard fit block mounted on the bottom triple on my 550, doesn't look to obtrusive in my opinion :)
Mounting the split on one of the calipers is fine in theory, but in practice I wouldn't recommend it, the second caliper in the line is a complete PITA to bleed properly :(
1978 CB550 K3
1985 H100S
« Reply #13 on: May 18, 2007, 08:17:30 PM »
1970s roadracing:
I just center-drilled and, cross-drilled 2 times, a longer bolt, then turned off the threads, sort of like the stock bolt, in two places (used a Dremel with cutoff disc). Then I stacked the two banjos of two stock brake hoses, one on top of the other, with one of the sealing washers in between the 2 banjos. I don't have any digital pix of it, but it's not hard to imagine it.   ;)
Then, after racing, I used it on the road for 55,000 miles like that. The lever travel was just less than twice stock, the controllability excellent (except on ice) and no fade ever, even with 600+ lbs aboard and 90+ MPH downhill canyon rides on trips. And, of course, many 1-up mountain race-with-self days...  ::)
I gave it up when I went on an unsprung-weight reduction campaign, then sold it when I got married and needed $$$, to another aspiring roadracer.
To do it over on a 450 or 750 today, I would use the smaller ones from the CB500 chassis with custom mounts, to reduce the unsprung weight. The stopping power will be quite adequate, even for repeated 110 MPH slows and stops.
pyro139
« Reply #14 on: May 18, 2007, 08:34:19 PM »
1981 cb650c had dual front if can get parts off a cb650c
Offline Blaize
  • Relax, God is make believe.
« Reply #15 on: May 19, 2007, 12:26:13 AM »
Why don't you just turn a cb750 splitter upside down? I presume you will use a modern M/C with the brake light switch built in so you can throw out the stock switch and you are in business. I did mine this way, works fine. I can't imagine you will find anything any smaller.
Living the American dream (in England).
Offline ProTeal55
  • Est1968.com
« Reply #16 on: May 19, 2007, 07:16:52 AM »
Thats the ticket ! I actually have my stock CB450 brake switch sitting in my toolbox..
Surprised I never thought of it (it happens)..
Is the stock/factory brake light pressure switch the same size as a banjo bolt ?
Offline Blaize
« Reply #17 on: May 19, 2007, 02:12:06 PM »
Yup, I have two of those splitters laying around and they all work fine. The threads are correct and the holes are deep enough.
Offline cben750f0
« Reply #18 on: May 19, 2007, 02:45:24 PM »
dam thats a good idea!!, whish i had of thought of that, i ended up wireing my brake light to the switch on my master, then double banjo at the Y block, no i can go back and flip it over and all will be sweet.... thanks mate!!!
 good luck with it pro..
peace
Offline bgfootball67
« Reply #19 on: May 25, 2007, 01:39:37 PM »
Check out this link:
http://www.spieglerusa.com/cfm/customline.cfm?type=940
Still have not figured out how to post pics yet, have not had enough time to go through the info on FAQ.  But while looking for stainless lines I found this line and thought it may work for you?  Looks pretty cool!
Columbus VinMoto
Ohio Cafe Racers website - http://www.ohiocaferacers.com
