Author Topic: Top End Gaskets  (Read 1514 times)
Undhwt
Top End Gaskets
« on: May 18, 2007, 04:44:36 PM »
Does anyone have information on where to obtain a Top End Gasket Kit w/seals for a 1977 CB 550K ?
Offline scunny
  • don't call me expert
Re: Top End Gaskets
« Reply #1 on: May 18, 2007, 05:05:44 PM »
don't know where you are but David Silver is a good place to start
http://www.davidsilverspares.co.uk/cgi-bin/dss2-cgi/Catalogue.pl
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline OldSchool_IsCool
  • Really feeling like an
Re: Top End Gaskets
« Reply #2 on: May 18, 2007, 07:13:10 PM »
Got mine from Western Hills Honda.
http://www.westernhillshonda.net/
Call and ask for the "vintage parts" desk.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline edbikerii
    • Gallery
Re: Top End Gaskets
« Reply #3 on: May 26, 2007, 07:08:23 PM »
I just opened my top end set (77 CB550K) after pulling apart the top end of my engine down to the cylinder head in order to fix an annoying oil leak.  Sure enough, the set did not include the rocker cover gasket, and did not include the breather cover gasket, either.  Unfortunately for me, the rocker cover gasket is the one that was leaking.
It did have the hockey pucks, though.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
croquesaveur
Re: Top End Gaskets
« Reply #4 on: May 27, 2007, 09:42:58 AM »
I rebuilt my top end last year using an Athena kit.  It stopped oil from weeping from the top end for a few weeks but the leak came back and in the spring it was bad enough that I had to do it again.
I rebuilt the top end again about a month ago.  This time I used Honda parts.  I replaced the oil gallery O-rings, the base gasket, the O-rings that go around the cylinders at the base, and the head gasket.  Total cost wasn't too bad... about $80 if I remember correctly.
I have put about 1000km (625 miles) on it so far and no sign of leaking.
If you want to take a look:
Disassembly: http://www.chrass.com/?p=162
Re-assembly: http://www.chrass.com/?p=174
There are a few other O-rings and gaskets that you might want to change while you've got it apart, but I recommend you use OEM for: the head gasket, the oil gallery O-rings, and the base gasket.
Offline edbikerii
    • Gallery
Re: Top End Gaskets
« Reply #5 on: May 27, 2007, 10:53:23 AM »
Sorry, I neglected to mention that this was the OEM top end gasket set I purchased from Western Hills Honda.  Part number: 16110-374-S01 "Gasket Set A".  $71.95 + $10.00 S&H.
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
