hei daniel
Seen quite a few guys doing it on all kind of racers around here, including a rob north framed Trident! Said guy had serious trouble with bearing life, essentially, even if you go up to 20mm bearings, these are not very robust. at least you did add a bearing to carry the chain loads, so that's good. The best setup I saw was from a guy that cut the hub in the middle, inserted a piece of ally tube and them re-welded to make the spacing between bearings wider, something that lowers the loads.
Still, would reccomend that you check your bearings often with this setup for wear, specally since you dont seem to have any drive shocks absorbing.
And BTW, thanks for your proposal on the carb needles. it ended up being some dirt causing the flooding. all is good now.
Cheers
TG
