Author Topic: Battery dying: differential diagnosis?  (Read 5007 times)
Offline medic09
« on: June 17, 2007, 09:10:54 PM »
Have been riding my bike without particular problems.  A few days back I blew a fuse while sorting some wires in the headlight bucket.  Replaced the fuse without thinking twice.
Today went for a good ride with my wife, then did some maintenance.  Valve clearances, timing.  No big deal.  Went for a test ride.  Rode okay.  Stopped for gas, and the starter wouldn't kick over; not enough juice.  The turn signals didn't work, either.  Kick started, and went home.
Checked the battery, and it's showing 8+ volts!  What happened to 12+?   ???
This is a fairly new (last fall) glass mat battery.  Am I correct in thinking that my daily commute (130 miles/round trip) should be recharging my battery?  That I shouldn't ordinarily need the charger?  That something is wrong here, as of today?
The only other recent changes have been that I've put PIAA bulbs in the headlight and signals, and Tailblazer (name?) blinking bulb in the taillight/brake light.  As far is I know, I have not significantly increased the amps drawn down here.  The rectifier and voltage regulator are new components from Oregon Motorcycle that I put in over the winter.
I've been riding the bike since late February/early March.  Having put it on the charger because I haven't needed to.
Can anyone help with my differential diagnosis?
Thanks!
« Last Edit: June 17, 2007, 09:25:18 PM by medic09 »
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline 750goes
  • it will live
Re: Battery dying: differential diagnosis?
« Reply #1 on: June 17, 2007, 10:49:38 PM »
what are the power consumption ratings (watts?) of the headlight and flashing lights ?? - if its a high powered light you could be draining the battery as you ride ??
apart from that  - give the battery a charge and then do a test with the bike runnning and measure the voltage drops as you turn on the offending items (just wind your idle up to say 3500 for the experiment)
Offline medic09
« Reply #2 on: June 18, 2007, 04:14:28 AM »
The demand of the new bulbs is within the range of the standard stuff; or so the manufacturer claims.  I didn't do the arithmetic, but with claims of no additional drain, I didn't anticipate problems.
I charged the battery last night, so that I can check it before I dare ride on my commute this morning.  I *really* don't want to take the car...
Mordechai
'78 CB750K
Santa Fe, NM
Offline medic09
« Reply #3 on: June 18, 2007, 05:22:01 AM »
Well, this AM it starts right up.  ~12.5 volts resting, ~13.5 volts (?!) at about 3,000.  Shouldn't that be more like 14?  The charger didn't showed 'finished' yet, so I put it back on while I get ready to leave.
Mordechai
'78 CB750K
Santa Fe, NM
« Reply #4 on: June 18, 2007, 06:06:55 AM »
You are right that isnt enough. resting volts, fully charged, shouold be 13.2 (2.2 volts standard per cell x 6 cells) charging volts shoult be 14 -14.5.
You have one of three faults.
(1) disconnected wire(s)
(2) bad connectors
(3) bad regulator/rectifier---just cos its recently new dont mean its still OK
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #5 on: June 18, 2007, 06:41:42 AM »
"Resting" is with the ignition off, right?
You certainly won't get 13.2V with the ignition on (no engine running)
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
« Reply #6 on: June 18, 2007, 07:12:02 AM »
Yup Steve that is fully charged with no drain at all, because they are "nominally" a 12v battery and described as such people think 12 is fully charged, its only when you go back to the school physics basics and remember that the acid cell gives 2.2 volts and there are 6 of them in series you get the 13.2 volts that our batteries should be at when fully charged and of course you need a differential to charge them, without going so high as to boil of the fluid, so thats where the 14.2-14.5 that most electonic regulators are set at comes from (28.4 on HGV with 24 volt system)
Offline medic09
« Reply #7 on: June 18, 2007, 07:19:36 AM »
Well, Bryanj, if those really turn out to be the only likely possibilities for a differential dx, that won't be so bad.  I did my morning commute (~65 miles, mostly highway speed), and packed along my multimeter.  When I go back out later, I'll take a quick look at the battery again.  I've got the old reg and rec, so I can do a little experiment when I have time at home.
Anything else I should be looking for?
Mordechai
'78 CB750K
Santa Fe, NM
    • TVAM
« Reply #8 on: June 18, 2007, 07:25:13 AM »
Make sure the battery earth (-ve) strap makes a good connection with the frame. It doesn't matter how good your reg/rec is, if this is anything other than "good" you'll always have problems.
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline medic09
« Reply #9 on: June 18, 2007, 07:31:36 AM »
That's why I ask you guys!  ;D  I wouldn't have thought of that...
Mordechai
'78 CB750K
Santa Fe, NM
« Reply #10 on: June 18, 2007, 07:59:36 AM »
An easy check with a voltmeter is at any "hot" connection check the voltage between it and the battery ground terminal direct and also betwen it and the engine---shound be the same, if not you have a bad ground point, you can also put a probe on each end of the ground wire and see if there is a voltage, if there is there is a problem--used this for years on Fiats which had notoriously bad ground cable connections which caused flat batteries
eldar
« Reply #11 on: June 18, 2007, 08:36:11 AM »
13.2 when off? I never have had a battery read that even when fully charged. 14.5 volts is getting into the dangerous range for charging the battery too. Gets close to boiling after a while. 14 is ok but anything in the 13 range is ok. Even cars I have had never charged at anything above 14 and this includes metros, nissans, hondas, or even old fords. My nissan did it once, when the vr was bad.
    • TVAM
« Reply #12 on: June 18, 2007, 08:58:00 AM »
As Bryan says, the 13.2V is a theoretical maximum. Even brand new batteries will fall a little below this.  My bikes (including my modern ones), sit at about 13V when off.
« Last Edit: June 18, 2007, 09:03:19 AM by SteveD CB500F »
SOHC4 Member #2393
2015 Tiger 800 XRT
    • TVAM
« Reply #13 on: June 18, 2007, 09:02:43 AM »
Just measured my Triumph.
12.9 off
12.5 on
14.2 at 3k rpm
That's solid state electronics and modern gel battery (same chemistry though!)
SOHC4 Member #2393
2015 Tiger 800 XRT
« Reply #14 on: June 18, 2007, 09:45:24 AM »
For lead acid batteries, 13.2 V is the peak surcharge reading you should get just after you disconnect the charger.  A fully charged battery that as "normalized" after about an hour or two is 12.7 Volts.
http://www.yuasabatteries.com/faqs.asp?action=1&id=14
Vehicle charging systems usually try to maintain an operating battery at about 13.8 V with 14.5 Volts being the upper limit, above which electrolysis starts separating hydrogen and oxygen from the electrolte (looks like boiling).
eldar
« Reply #15 on: June 18, 2007, 11:20:41 AM »
Yeah my Batt sits at about 12.6 or so a couple after riding. Around 13.3 or so when above 3000rpm, maybe slightly higher but not above 13.7.
Offline medic09
« Reply #16 on: June 18, 2007, 03:25:13 PM »
Okay, so I charged the battery overnight.  It showed about 12.5v key off, and about 13.5 @ about 3000 rpm.  I rode my commute, about 65 miles, mostly on the highway.  Parked the bike for about 7 hours.  Ambient temp reached about 30 C, 50 in the direct sun.  Before I started off, I checked the battery.  It showed 12.77v without key, and 15+  :o at about 3500 rpm.  Rode home.  The battery showed 12.94 without key, 12.53v initially at idle, 15+ at about 4000 rpm, and 13+ at fast idle.
I guess I should switch out my voltage regulator?  Presently I have a fairly new solid-state unit; but I have still have the old original.
Mordechai
'78 CB750K
Santa Fe, NM
eldar
« Reply #17 on: June 18, 2007, 03:36:32 PM »
You might want to do that and see what happens. I would rather have a battery go dead from not enough charge than fry it from too much.
« Reply #18 on: June 18, 2007, 04:42:38 PM »
I don't know what color wires your new regulator has.  But, the old one used the black wire to sense what the battery voltage was and made decisions on controlling the alternator based on that.  Were I you, I would check to see that the black wire at the regulator had the same voltage as the battery.  If not, find out why and fix it.
Offline medic09
« Reply #19 on: June 18, 2007, 05:17:06 PM »
Thanks for that tip, Lloyd.  The Oregon Motorcycle reg uses the same wires; it is plug and play.  Where would I put the probe to check this?  Do unplug the black wire from the reg while the engine is running, positive probe to black wire, black probe to ground?  Like all my other problems, this is learning as I go along.
Mordechai
'78 CB750K
Santa Fe, NM
Offline medic09
« Reply #20 on: June 18, 2007, 05:37:31 PM »
Methodology question:
How do I read the meter?  It shows an immediate reading, then very slowly continues to creep up over more than a minute or so.  It starts in the low to mid 13s, and creeps up over two minutes or more.  So what value am I actually using?
I unplugged the black wire from the reg.  With the red probe to the black reg wire, and the black probe grounded to the engine, it showed 11.54.  The batter showed mid 13.   ???
Mordechai
'78 CB750K
Santa Fe, NM
« Reply #21 on: June 18, 2007, 06:36:45 PM »
Ideally, you want to measure the black wire while it is under load and carrying current to the alternator.  It won't do this while disconnected from the regulator.  Simply turn the ignition switch on and measure the black and green wires at the regulator terminals without the engine running, and then quickly make a measurement at the battery terminals as your battery voltage will be falling due to the ongoing drain.
The battery voltage slowly rises as it is being charged with the engine running fast enough to make more power than being used by the bike.
The electric stater motor draws about 1800 watts per second out of the battery.  The stock bike electical load is about 120 watts per second.  Your alternator will make about 40- 50 watts per second at 1000 RPM-ish, and can make 210 Watts per second at 5000 RPM if the regulator allows it.  At some RPM, specific to your bike, the alternator output will be exactly what the bike uses.  Higher RPM will begin charging the battery and the voltage should rise.
If the regulator can properly sense the true battery voltage, it should react by limiting the alternator output so it can't over charge the battery  (above 14.5 V).  If the battery is at 15.5 V but the regulator only "sees" 12.5 (for example) on its black wire, it will think the battery isn't fully charged yet and allow full output of the alternator at cruise speeds.  Battery life will diminish.
Offline medic09
« Reply #22 on: June 18, 2007, 06:45:11 PM »
I'm showing 11.38 at the green and black wires, and 12.38 at the battery terminals.
Mordechai
'78 CB750K
Santa Fe, NM
« Reply #23 on: June 18, 2007, 06:51:45 PM »
Okay, rev the alternator till the battery voltage peaks,  (or goes above 14.5)  and then read the black and green wires and then the white and green wires while the alternator is still reving.  At that battery voltage the regulator should provide reduced voltage on the white wires.  If not, try another regulator.
Put, a window fan in front of your engine.
Offline medic09
« Reply #24 on: June 18, 2007, 07:02:44 PM »
The black/green showed around 11.38 again, the white/green showed 0.  I tried three times.  0.
Mordechai
'78 CB750K
Santa Fe, NM
