Author Topic: seized engine  (Read 1528 times)
drey
seized engine
« on: June 29, 2005, 07:56:18 PM »
was up out der? im all new to this forum thing and bikes ,but i gat a 1975 honda 750 four ohc ,and it sat for at least 8 years in someones back yard ,it did have the pipes and carbs on it all on the bike still ,but when i moved it to bring it home it was stuck in gear . so its all seized up ,and i gat advice to take out the spark plugs and fill the cylinders with a penatrating oil ,which i did ,and i also drained the oil and put atf in the oil fill and let everything soak for a day. i came home from work 24 hours later and rocked it back and forth 2 or three times and its rollin! that made me happy,but where should i go from here? should i rip out the engine and do a full rebuild ?and does anyone have any idea's or hazards to watch out for before i get on with the next step? im have in fun and learnin as i go this is my first bike so i would apreciate any help........thanks ..........Drey...........L8R
Buffo
Re: seized engine
« Reply #1 on: June 29, 2005, 09:20:20 PM »
The best advice i can give you is "start buying cheep beer".
You will need the extra money. ;D
Buy a clymer or haynes repair manual.
Get a Dennis Kirk catalog. WWW.denniskirk.com
Go out and buy a good Impact driver and a rubber coated dead blow hammer. 1 or 2 pounder
When you take out the phillips head bolts replace them with allen head bolts. The phillips head bolts strip out real easy, hence the impact driver.
Take good pictures of your bike before you take it apart. So you can have some type of idea how to reassemble it.
When you take the case covers off make a template of the case cover pattern in card board and poke holes where the bolts go. then one at a time take the bolts out and stick them in the proper hole in the cardboard. This is a good tip!!!
when you srtip screws or round bolts off  go to sears they sell good easy outs and bolt removers.
When evr you take out bolts (especially case cover bolts) put some anti-sieze on the threads.
Listen to the wise words of Charles Emerson Winchester III :
  " Do one thing at a time, do it very well and move on."
Don
Offline jotor
Re: seized engine
« Reply #2 on: June 30, 2005, 06:13:15 AM »
If the engine turns over, I think I'd clean up the carbs., etc. and try to start it.  Who knows?  It might run fine.  If not, you haven't lost anything.
P.S.  Be sure to replace ATF first.      ;-)
I'd rather ride a Yamaha than eat worms.
Gallery.....http://www.sohc4.us/forums/index.php?topic=2254.0
