Author Topic: Spark Plugs  (Read 4403 times)
tophe7d
Spark Plugs
« on: June 28, 2007, 08:48:16 PM »
I must plead ignorance...  ::)
I had a lot of ignition misfire problems at all rpm ranges. I screwed with the points/condensor and ignition timing over and over before I gave up on that. I replaced the coil wires with a nifty thread that I found on this handy website forum (it works!)  ;D
Anyways, after screwing around with all of that, I still had a misfire problem. I had originally ruled that the plugs were good because when I hooked up the timing light to each of the plug leads, they were all firing... Not very well, but still firing. I thought that because the light was flashing, they were ok. I thought that when plugs went bad, they stopped working period. I was wrong.
Well my cheap ass finally bought a new set of plugs today and WHAT A DIFFERENCE!!! No more misfire. Smooth as a kitten. I can't believe that I wasted so much time and effort on other crap when all I had to do was spend $12.00 on some plugs.
Bottom line, when trouble shooting ignition stuff, replacing the old spark plugs should be the first thing you do!
Just thought I'd share.
Chris Thornton
« Last Edit: June 28, 2007, 08:50:36 PM by tophe7d »
mussamatt
Re: Spark Plugs
« Reply #1 on: April 28, 2009, 06:07:12 PM »
What is the thread? I think I may have read what you're referring to, but I cant find the thread.
