Author Topic: h4 headlight wattage recommendations wanted!  (Read 2158 times)
Steelo
« on: July 02, 2005, 11:39:42 PM »
I have a 750 k7 and am tired of riding in with headlight output similar to my cars parklights. I'm going to upgrade to H4 halogens. What wattage combinations should I use and do I have to replace the existing wiring with a stronger system. If so can someone send me a simple wiring diagram.
Offline Egil
SV: h4 headlight wattage recommendations wanted!
« Reply #1 on: July 15, 2005, 10:17:09 AM »
Go for the H4 60/55W + 20 % or 50%
But rember to put ,twise big earth cable from light and 1 extras earth cabel (6>8mmØ) from Light/front fork to the frame and a weery good earht connected .
I have connected  my headlights via a Xtras relays connected like you put xtra beem (on your car)
Mounted a 8 mmØ cabel from positiv + side of the starter switch (relay) put a BIG AGU fuse like those they jus on to Big-car stereos!
mounted a dobbel relay (for high and low beam)  from relay to the headligt I take 8mmØ   us the xsting cabel to stear the relay.
WERY importet you MUST have sam size of cabel in on the+side  lighbulb ase you have on the earth side  or it have no use.
Have i nice MC weekend
Regards
From  me and my CB750K7  in Norway
Egil.
« Last Edit: November 12, 2005, 10:42:32 AM by Egil »
73 de La2vpa.
Egil.
On The Edge.....That`s Where We Live Every Day.
My bike :
http://bike.no/member/photo.php?id=1605
Offline Mossy21
  • It takes "Time" to be a Classic..........
Re: h4 headlight wattage recommendations wanted!
« Reply #2 on: July 16, 2005, 04:45:23 PM »
I installed a H4 55/60 in my 1978 CB750K and found the light not as bright as it should be.....Does the extra wires fix this problem?
If I can't see the Engine I can't see the point.......
« Reply #3 on: July 16, 2005, 06:44:46 PM »
I've got a 55/100W halogen light on my K2 Ian, it was jast a plug in deal and works fine. Cheers, Terry. ;D
Offline Dennis
« Reply #4 on: July 16, 2005, 10:20:57 PM »
Mossy, sounds like you have a voltage drop somewhere.
Check over your harness and clean the connectors. The light should work fine, the electrical load is only a little higher than stock.
I have the same bulb in my '75 750F, no problem, however I do use a relay in place of the starter button which failed before I got the bike. The problem could be there, I think your headlight is run through the starter button also.
Offline Mossy21
« Reply #5 on: July 17, 2005, 04:26:27 AM »
Dennis,  Thanks for the info....I'll take alook.
Offline Egil
« Reply #6 on: July 17, 2005, 03:09:24 PM »
Yes, Thanc you.
Nice.
Egil
« Last Edit: July 18, 2005, 12:56:20 PM by Egil »
73 de La2vpa.
Egil.
My bike :
Offline cben750f0
« Reply #7 on: July 17, 2005, 03:24:12 PM »
mate check this link... i was gonna give these lights a go... peace
http://forums.sohc4.net/index.php?topic=2656.0
« Last Edit: March 16, 2011, 04:25:11 AM by Glenn Stauffer »
