SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Swingarm grease fitting 78 CB750K
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Swingarm grease fitting 78 CB750K (Read 1333 times)
cjackel
Guest
on:
July 03, 2005, 02:13:37 PM »
I offer a few tips if you break off your swingarm grease fitting while attempting to
remove and clean prior to attaching grease gun:
1. Use a #2 size "Easy Out" or screw extractor
2. Use small needle nose vise grips to turn the easy out while exerting pressure into the broken fitting.
3. Buy a package of 6mm 45 degree fittings as straight fittings won't allow the grease gun to attach
and the 90 deg fitting won't rotate all the way around when installing it.
Logged
dpen
Hot Shot
Re: Swingarm grease fitting 78 CB750K
Reply #1 on:
July 04, 2005, 07:30:12 AM »
If you're hamfisted & keep braking nipples, a handy item is available from automotive shops etc.
One end fit s in the greasegun.
The other end is a tapered point that fits into the broken nipple in the swingarm.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
