Author Topic: PD 46a O-Rings  (Read 1198 times)
Offline Jay B
PD 46a O-Rings
« on: July 09, 2007, 07:02:20 PM »
Searched the FAQ's to no avail. Anyone know the O-Ring size for the carb to carb fuel fittings on these carbs? From a '77 550k.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Re: PD 46a O-Rings
« Reply #1 on: July 11, 2007, 07:20:46 AM »
No parts list shows those but the carb kits are the same as the 750Auto and you may have to buy a kit for one carb to measure the sizes
Offline Bodi
Re: PD 46a O-Rings
« Reply #2 on: July 11, 2007, 08:42:50 AM »
I expect Keihin uses the same sizes on most carb stacks, why stock a lot of different ones?
The fitting I have are 9mm diameter with a 2.5mm wide groove for the O-ring and the groove diameter is 6mm. The O-ring is 1.9mm cord with a 5.8mm I.D.
You can find these O-rings online. The biggest problem with metric O-rings is the vast variety. US inch size O-rings are standardized and there are only about 500 sizes that almost everyone designs around. There are thousands of metric sizes, I can't understand why they need 1mm, 1.4mm, 1.5mm, 1.7mm, 1.9mm and 2mm cord sizes... and on and on? Stocking every standard inch size is pretty easy, stocking every "standard" metric sizes would need an Indiana Jones warehouse.
Partsbiker
Re: PD 46a O-Rings
« Reply #3 on: July 11, 2007, 10:10:03 AM »
this site doesnt say what size but...
http://www.salocal.com/sohc/tech/carb/asmpg_mgs/rjoincrbs.htm
A/C O-rings are used. Aparrently still going strong after 4 years. Plus you could probably take the T-fitting into a local auto parts store and they can break out their box of O-rings and fit it for you on the spot.
