Author Topic: What did you pay for bore/hone?  (Read 5611 times)
Offline Big Jay
    • CBRzone
Re: What did you pay for bore/hone?
« Reply #25 on: March 10, 2008, 04:00:06 PM »
$95.00 for all four if we supply the pistons, $160 if you do. We are pretty much limited to 64mm and larger.
Jay
Offline crazypj
  • I'm brill, me
« Reply #26 on: March 11, 2008, 12:30:58 AM »
When you guys are talking big bore it is a lot of extra cutting..like  almost 1/8 of an inch coming out..whereas a normal cut is a 32nd or under.
Wait till you get into real big bore, there is one cylinder that I bore on the lathe, that get 1/2 inch taken out..over 12mm :o
So I rough them out to within a few thou, and then the automotive machine shop hones them..
Your doing 883 to 1200? (0.496" overbore)
 Usually, I'm in the 2~12mm range for overbores
 Biggest one I've done is a CJ250 out to 391cc, 14mm overbore (from 56mm to 70mm)
PJ
« Reply #27 on: March 11, 2008, 06:15:24 AM »
Yup883.. they are sooooooo thick!!
 Too bad our 750,s didnt have the meat to bore to 1000cc w/o sleeving..
