Author Topic: Stripping/ sanding/ scotch bright/ clear coating a gas tank?  (Read 977 times)
Meet The Twins
Basically I have a old CB500T that I just want to freshen up alittle. I was planning to use aircraft grade laquer (sp?) thinner, sand paper, scotch bright, and a rattle can clear coat to stop rust. Will the tank rust if I dont clear coat it?
Would that be the proper process of giving my tank a WWII fighter brushed aluminum look?
Just wanted to make sure I wasn't over looking something.
Thanks guys!
« Last Edit: July 14, 2007, 05:20:48 PM by Meet The Twins »
Offline Slapguts
Re: Stripping/ sanding/ scotch bright/ clear coating a gas tank?
« Reply #1 on: July 14, 2007, 08:48:02 PM »
It will rust in about an hour if you don't clear coat it. Even if you do, it will start to rust under the clear. You could always lay a LOT of clear on it, and keep it very well waxed. Should slow it down a little.
THought about zinc plating it?
Current-
'76 CB550 Cafe project
Past-
'98 Triumph Speed Triple-Stolen
'76 CB750 Cafe Racer-Sold
'78 CB400T Crash Victim-Traded for a tattoo
Meet The Twins
« Reply #2 on: July 15, 2007, 12:50:40 PM »
^No sir I havent, Any idea how much that would run me?
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #3 on: July 16, 2007, 07:24:55 PM »
If u want the raw metal look, just have it ceramic coated and polished (like a set of headers), then take a scotch brite pad and some WD40 to it and dull it up.
Exile does this to almost every part they sell for that "raw" look...
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: July 17, 2007, 09:48:22 AM »
I agree with proteal....that method works very well, is very durable, and above all, looks killer.
