Author Topic: Petcock and Ignition Switch  (Read 929 times)
Offline dachoklit1
« on: January 27, 2008, 09:33:00 AM »
Good day. I have the tank off the bike at the moment. When the petcock is turned on, is the fuel supposed to come out of both holes? Because it's only coming out of one. Also, is there a tool required for removing the ignition switch? The bike is a 73 CB 750. Just trying to get back on the road! Thanks!
« Last Edit: January 27, 2008, 09:44:46 AM by dachoklit1 »
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
Re: Petcock and Ignition Switch
« Reply #1 on: January 27, 2008, 11:18:20 AM »
Like DG says, the metal is soft enough to manually unwrap from the frame once the bolt is removed.  Assuming you've got the tank off and the wiring unplugged, its real easy.
