SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Tach Seal - which way?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Tach Seal - which way? (Read 1867 times)
75750SS
Enthusiast
75 750F, 2010 Concours ABS
on:
July 27, 2007, 10:17:22 PM »
In my haste, I forgot which way the seal goes into the cyclinder head cover. Is it Flat Side facing out or is it the Cupped side facing out or does it even matter? 75 750F
Logged
TwoTired
Really Old Timer ...
Re: Tach Seal - which way?
Reply #1 on:
July 27, 2007, 11:28:44 PM »
That's a lip seal and itr matters. In this case and in general, seals are installed so that molded in numbers are visible after installation, or facing outward.
Logged
jdpas29
Hot Shot
my bike is 100% sandcast!!
Reply #2 on:
July 28, 2007, 06:10:42 AM »
and for what it's worth... if your seal was as big of a piece of stool as mine was, you'll need to make sure you get every smidgen of leftover seal out of the little ring-groove that is in there around the outside. my old seal was basically burned in there and i had to scrape it out with various tools in order to get a half decent seal out of it... and it still weeps a little.
Logged
cars are gay.
obnoxshuz
Guest
Reply #3 on:
July 28, 2007, 05:03:03 PM »
How do you take the old one out? I tried using a wooden screw to attach to it but no luck.
Logged
75750SS
Enthusiast
Reply #4 on:
July 28, 2007, 06:33:33 PM »
That's how I got mine out. Drilled a small hole then screwed in a wood screw as far as it would go. Pulled it out with pliers.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
