Author Topic: Which Pod air filters for my '77 CB550k and where can I get them?  (Read 1808 times)
scadaman29325
I've heard that the 'tapered' pods will not fit on the outside carbs due to the length of the pod being too long and hitting the frame.
I've also heard that the 'straight' type will fit.
I think the OEM carbs are 39mm.
Has any one found these at a reasonable price? The K&Ns are good but expensive.
TIA
Phil
Offline mmtsquid
Re: Which Pod air filters for my '77 CB550k and where can I get them?
« Reply #1 on: August 17, 2007, 05:34:35 AM »
Well, The cheap e-bay tapered pods won't fit unless you trim the rubber boot that attaches to the carb.
I have the same bike, and went through hell trying to make it work - jets of MANY different sizes, needle position, etc.
I wound up taking the darn things off and running the stock setup, and I'm much happier now.
Search for the thread "pods vs standard air box", and you can read all about it.
One poster (edbikerii) was successful in getting pods to work, and he documented his set up.
Good luck to you!
Rick
77 CB550K4
Offline neil young
  • striving to be an
« Reply #2 on: August 17, 2007, 07:34:18 AM »
Good luck to you!
Rick
yep it appears Ed has done a lot of research on this.there is a thread on page two or three where he explains all
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #3 on: August 18, 2007, 03:52:27 PM »
UNI-s are great, look good too, AND they compress real nice to fit on 1&4 AND they are cheaper...
http://www.unifilter.com/onlinecatalog.html
HONDA MOTORCYCLES cont’d
CB 500/550 (4cyl.) Thru ’81 NU-4055
« Last Edit: August 18, 2007, 03:57:48 PM by chippyfive50 »
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #4 on: August 18, 2007, 04:34:35 PM »
Here's a post with pics, measurements and a link to where I got mine.
http://www.sohc4.us/forums/index.php?topic=24352.0
1977 CB750
Offline edbikerii
    • Gallery
« Reply #5 on: August 18, 2007, 05:27:33 PM »
My Emgo pods fit perfectly on my '77 CB550K.  See this message for where I got them, etc:
http://www.sohc4.us/forums/index.php?topic=22036.msg254555#msg254555
When you discover that you need to rejet, save yourself a lot of headaches and go straight to this:
http://www.sohc4.us/forums/index.php?topic=22036.msg258435#msg258435
Good luck!
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline GammaFlat
« Reply #6 on: August 18, 2007, 08:22:56 PM »
I have a set of K&N (tapered) pods I bought for my 750 K6 years ago.  They were on the bike for about 20 miles (at most).  I've heard that they may be a different size.... If you think they're an option, let me know and I'll measure them and take pics for you.
Rick does make a good point in a previous post.  There's a reason I went back to an airbox and standard filter (like Rick did).  My vote: reconsider stock airbox.
John
K6
85 Goldwing
Offline jdpas29
  • my bike is 100% sandcast!!
    • My band = white bread
« Reply #7 on: August 19, 2007, 07:30:50 AM »
you can get them at the 7th level of hell because that's where they're made.
happy repetitive, neverending carb tuning!!!   :P
i hate pods, but i'm not bitter...
cars are gay.
Offline edbikerii
    • Gallery
« Reply #8 on: August 19, 2007, 01:24:37 PM »
This is what the pods look like on my '77 CB550K:
When you take your time and rejet properly you can get excellent results.
« Last Edit: August 19, 2007, 01:26:49 PM by edbikerii »
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
scadaman29325
« Reply #9 on: August 20, 2007, 11:17:51 AM »
I must have had crainial rectumitus when I did the 'search' before I posted this topic....  I couldn't find anything about pods for the 550...
Wow 'two timer' (oops, 'two tired') sure is a wealth of knowledge.
Thanks for the input and photos!
After reading about 4 pages I ordered a stock setup. (I've already got enough problems to deal with.)
Thanks again!
Phil
