Author Topic: Clutch problem.  (Read 1124 times)
Glenn
Clutch problem.
« on: August 27, 2007, 07:18:48 AM »
     I just registered and sent an introductory email, but I found a great site that I wanted to share.
     I recently pulled my clutch to inspect the clutch rings.  I tried too many time to reinstall it, but each time the actuator was not making contact with the clutch bearing.  I hunted extensively through other this and other forums to find an answer.  I ran across another person having the same problem (I can't find him again).  Somewhere, I was directed the below web site.  It was by far the best I have found, and I wanted to share it with others.
     www.salocal.com/sohc/tech/tech.htm
     I hope this helps someone.
Thanks,
Glenn England
PS  I had the conical washer turned backwards.
