The only problems I had fitting dual discs were,
1. Brake and tyre wear (when you know you can stop you leave braking that much later and ride faster as well
) went from around 6,000 miles on front tyre to 2,500 and 6,500 to 2,000 or less on brake pads ( burned one set out the same day I fitted them, EBC green work well in the wet but dont try more than one real hard stop in the dry, about 200miles total, and cooked brake fluid)
2. fender bracket, use spring washers to take up play in the mounting holes when rubber cushions are removed ( I really dont like the idea of a rubber mounted fork brace?)
I didnt use the metal lines, fitted Aeroquip 3 piece, over length to go direct from splitter to caliper.
I just turned 49, dont ride as fast anymore but still leave braking way to late, on third front tyre and 4th set of brake pads in 16,500 miles
PJ
