Author Topic: Primary and cam chains  (Read 1432 times)
Offline Patrick
« on: September 26, 2007, 10:31:30 AM »
I have two sets of primary chains and two cam chains that cam with my project K0 750. One set of primary chains and one cam chain were in the bike when I split the cases, The other sets were in baggies in one of the bins of spare parts that came with the bike. Is there any way to tell which of these chains is the better choice? I might just go ahead and buy a new cam chain, although both of these look good, but the primary chains are different,far more expensive matter.
I have to assume that the PO thought the chains included with the spare parts were good. Everything else he had in the bins, (except possibly the con rods which are yet to be examined), was better than what I found in the bike. That doesn't mean, though, that he examined the primary chains prior to acquiring the back ups. Since I have the cases open already,  I'd like to use the best choice.
Any help would be appreciated.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline scunny
  • don't call me expert
Re: Primary and cam chains
« Reply #1 on: September 26, 2007, 12:04:09 PM »
hang your chains on a nail, the more worn one will droop more
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #2 on: September 26, 2007, 02:05:15 PM »
Patrick, the Honda manual describes how to check the primary chains fitted to the motor - easy to do. I would also try and contact the PO and ask him about the condition of the spare set of chains - they may be new. Pat from Australia.
Regards
Pat from Australia
Offline Patrick
« Reply #3 on: September 26, 2007, 02:47:33 PM »
Thanks, guys. I did the hanging on the nail thing and the spare chains are a good quarter inch shorter than the chains from the bike. The PO who acquired the chains is in the distant past. The person I bought the bike from bought it in 1991 with the intention of restoring it, but then happened upon a 1962 Corvette and decided to restore that instead. I can't say I 0disagree with that choice. I've seen the car. It's beautiful. The K0 sat in a corner of his five-car garage until he managed to fill it up and needed the space.
The backup chains were in one of several bins of parts that came with the bike. The last PO never really even went through the bins after the 'Vette captured his attention.
On closer inspection the cam chain is still coated in packing grease, so I believe it is new. The primary chains also "look" really good.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Clyde
« Reply #4 on: September 26, 2007, 07:09:09 PM »
Pat,
It is easy to check the primary chains by assembling the crankcases with crank, clutch/mainshaft and tensioner. Just put a few of the larger bearing bolts in the make sure it is done up tight.
Then turn the crank over a few times to allow the tensioner to do its job properly. Measure the distance from the sump pan face to the arm of the tensioner.
A new primary chain meaures about 65mm and Honda has specified a max of 70mm.
I check all my chains and if it is 68mm or more, replace the chain.
Regds Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline Patrick
« Reply #5 on: September 26, 2007, 07:19:34 PM »
Thanks, Clyde. But the chains are endless. How do you measure them?
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Patrick
« Reply #6 on: September 26, 2007, 07:21:14 PM »
Never mind. I've been wrenching too long today...
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Clyde
« Reply #7 on: September 26, 2007, 07:54:48 PM »
I did forget to mention that you must also install the chain!!!!!  ;D
SOHC4 #1909
