Author Topic: headlight ear options for a '71cb750k1?  (Read 1148 times)
newcbguy
« on: October 29, 2007, 08:03:10 AM »
hello, I have been searching for awhile for some info I came across awhile back that said what headlight ears were compatible with my setup. I found a good set off a '80+ dohc 750 that are in good shape but have HUGE turn signal lamps on them that are an eyesore. Can I get some cb500 or cb550 headlight ears that will work?
Offline eurban
Re: headlight ear options for a '71cb750k1?
« Reply #1 on: October 29, 2007, 08:11:36 AM »
Don't know about 500/550 ears.  Look in tricks and tips section under cafe headlight ears.  There should be some links for you.  You can get a variety of aftermarket headlight ears that will do what you want and look nice and clean.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #2 on: October 29, 2007, 08:20:13 AM »
Got the ears on my CB450 from MikesXS.net for around $50 --->
Def. better than the cheap-o ones you see allot on these bikes...
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #3 on: October 29, 2007, 08:25:31 AM »
I bought osme nice aluminum ones from a local shop here. 50ish bucks or so. Can't remember the brand name, will look it up later.
No.
newcbguy
« Reply #4 on: October 29, 2007, 09:02:20 AM »
thanks for the replies, I have seen the aftermarket ones, and actually have a pair of the cheap chrome emgo ones. My tubes are not pretty enough to mount the aftermarket ones however so I would like to put the oem style back. so does anyone have any insite as to which ones will work? I know that 400-750 have the same diameter tubes but what I dont know is the distance between top clamp and bottom clamp. Anyone?
Offline ProTeal55
  • Est1968.com
« Reply #5 on: October 29, 2007, 11:40:25 AM »
Pretty much all of the CB bikes ran 35mm fork tubes.
As long as whatever u buy fits 35mm tubes you are gold..
Offline Clyde
« Reply #6 on: October 29, 2007, 06:01:53 PM »
From memory the 400/350 used 33mm forks???
Best check
Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
