Author Topic: Help! stripped oil filter bolt.  (Read 1970 times)
vacafe
« on: July 22, 2005, 11:34:02 AM »
Anyone have a good idea how to get a stripped oil filter bolt out?  I have tried everything but cutting it off!
Offline gkw120649
Re: Help! stripped oil filter bolt.
« Reply #1 on: July 22, 2005, 11:37:47 AM »
Pipe wrench, Vise Grips, Weld a socket to the bolt, Try and hammer (gently) to the head of the bolt.
Greg in Chicago.
1977 CB-750 K
1978 CB-750 K
Offline gkw120649
« Reply #2 on: July 22, 2005, 11:40:05 AM »
I meant to say - hammer a socket on the head of the stripped bolt.
1977 CB-750 K
1978 CB-750 K
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
« Reply #3 on: July 22, 2005, 01:53:04 PM »
Check the FAQ and check the archives (http://glennstauffer.com/smf).  This is a common problem and there are good posts on the subject - though Greg has already given you a summary of the best solutions.
Hop on a Honda
« Reply #4 on: July 24, 2005, 05:07:48 AM »
Try to drill a 1/8 hole through the remaining head.
Then put the drill bit through and use that as a purchase to relieve the tension .
IT Does work
Dave
