Author Topic: 77 750K Float Level  (Read 3530 times)
dwheil
77 750K Float Level
« on: April 08, 2005, 07:29:42 PM »
Been working on getting my 77 750K  going again, after a 12 year nap in the basement. I cleaned the carbs and installed my "new set" of pipes, and the bike started right up. Then the carb leaking started. I think I may have messed up the float setting.  Need to find the float level setting and where the measurement is referenced.
Thanks
Dennis
Offline Warlock
Re: 77 750K Float Level
« Reply #1 on: April 08, 2005, 07:44:30 PM »
According to the Honda Service Specifications book, the 1977- 750K float setting should be 12.5 mm with the stock
model 41A carbs...
Ride On...
dwheil
« Reply #2 on: April 08, 2005, 07:53:09 PM »
Hey Warlock
Thanks for the info. Is the measurement from the float bowl surface? And where on the floats is the measurement point?
Thanks again
Dennis
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #3 on: April 08, 2005, 08:35:24 PM »
Hi Dennis
Get the float to where it`s just touching the needle without compressing it and then measure from the carb body lip to the top of the float.The pics below are from a CB500 but the same principle.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
dwheil
« Reply #4 on: April 09, 2005, 04:44:07 AM »
Got it.  Thanks for the info, hopefully this will solve my problem. I'm trying to not have to rebuild the carbs.
Dennis
Offline Harry
    • CB500F
« Reply #5 on: April 09, 2005, 04:56:23 AM »
FYI I would like to use this picture for the FAQ - is that ok?
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
Offline Einyodeler
« Reply #6 on: April 09, 2005, 05:55:42 AM »
Sure Harry,kein problem ;D
