Author Topic: Is this a good gasket set??? (pic)  (Read 1506 times)
Offline L.A. Nomad........
  • 1976 CB550 K
« on: December 05, 2007, 04:30:23 PM »
I don't see a brand name.
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
Re: Is this a good gasket set??? (pic)
« Reply #1 on: December 06, 2007, 04:37:27 AM »
Looks like a 500/550 set with everything in it for a top end job, no idea on name or quality tho'
h8r
« Reply #2 on: December 06, 2007, 06:13:23 AM »
I wouldn't bother replacing the hard-to-reach gaskets without being sure they were high quality. Head and base gaskets are too much effort to have to redo. Not worth trying to save $50. Ask me how I know.
Offline tomkimberly
« Reply #3 on: December 06, 2007, 06:35:14 AM »
I tried one of those kits on a 650. IMO it is a POS. Poor fitting and not all of the "O" rings are included.
The 2nd time around I bought OEM from my Honda dealer.
Tom
Offline dusterdude
« Reply #4 on: December 06, 2007, 06:58:53 AM »
how do you know  ;D
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
h8r
« Reply #5 on: December 06, 2007, 11:32:02 AM »
how do you know  ;D
I bought a gasket set from CycleX... here's the blurb direct from their website:
"Cycle X gasket sets are better!!!!!!!!! Honda CB 750 SOHC.
Athena gasket sets are missing the  "o" rings for the valve inspection covers.
Vesrah gasket sets are missing the 6 cam tower plugs ( quarter size plugs under the cam tower )
Our gasket sets are COMPLETE, with all necessary gaskets and "O" rings for a rebuild. ( oil seals are separate )
Cycle X head head gaskets have a bigger fire ring around the combustion chamber ( that's  good )
Cycle X head gaskets are made with metal layers and impregnanted with gasket material to resist the need to  re-torque ."
What they don't say is that their gasket set is EMGO, ie cheap Taiwanese paper. I figured if I spent $80 on it I might as well install it and see if maybe they're right and I misjudged the quality. Nope, leaky headgasket and leaky valve cover. Going to replace with either Cometic or OEM over the winter. Not looking foward to pulling the engine again.
Offline dusterdude
« Reply #6 on: December 06, 2007, 12:12:50 PM »
shiite,i think i would be pissed.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
