Author Topic: Help wanted for conversion from front disc brake to drum brake  (Read 4483 times)
Offline yd72
« on: January 10, 2008, 12:03:53 AM »
I am thinking of converting my cb350f into drum brake.
I read that gt750 can be used for converting into drum brake for this bike.
Anybody has any idea where can I find this set up, any website recommedation?
Or any other set up that is suitable for my bike that is not too costly.
I am in for all ideas and recommendations.
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
Re: Help wanted for conversion from front disc brake to drum brake
« Reply #1 on: January 10, 2008, 03:31:03 AM »
why would you want to go from a front disc to a drum??? ??? ???
« Last Edit: January 10, 2008, 03:33:27 AM by cb350twin »
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Bob550four
« Reply #2 on: January 10, 2008, 03:37:13 AM »
I have to agree.  going to drum is madness.
Offline 736cc
« Reply #3 on: January 10, 2008, 04:05:42 AM »
   You may consider that a used GT750 J model dual front brake drum set-up on ebay will fetch over $500
Offline flankspeed
« Reply #4 on: January 10, 2008, 07:20:16 AM »
The guy I bought my 350f from put a drum brake from a cb350 twin on it to make it look "more vintage".  It works ok but I will be putting the original setup back on sooner or later.  If you want I can take some pics of it this weekend.
1973 cb750
1971 Triumph 650 rigid
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #5 on: January 10, 2008, 08:20:05 AM »
Like 736cc said.....a pre 1973 GT750 drum brake is gonna cost you some money. I've seen one's that look like they were sitting at the bottom of a lake for 20 years.....end up selling for several hundred dollars.
If all you want is a drum brake.....find a 1972 Honda CB350 K4 twin. That 2LS drum front wheel will bolt right up to your CB350F forks with no mods. Make sure you get all the hardware like the brake stay...etc. Also....your gonna have to swap out your front brake lever/switch housing.
Hope this helps,
Greg
« Reply #6 on: January 10, 2008, 08:45:33 AM »
You guys should maybe trade..
Offline Steve F
« Reply #7 on: January 10, 2008, 09:36:21 AM »
See if you can get a front end off a CB360 twin...around I think a 1974 or so ( don't understand the logic of going to a drum brake, but to each his own  ??? )
Offline Geeto67
  • A grumpy
« Reply #8 on: January 10, 2008, 10:21:20 AM »
I have seen a lot of cb350 twin racers use the Suzuki T500 front drum. The only issue is that after a couple of seasons of hard racing the hubs begin to crack. For street riding however I doubt you are ever pushing it hard enough to make cracking an issue.
Unless you need the drum for a racing class (WERA and AHRMA both have classes where the 350 would be eligible but has to run a drum), going to a front drum for looks is pretty dumb. Plus the 350F doesn't really go fast enough to overpower that front disc.
While a drum does have more overall stopping power than a disc, the advantage the discs had was control and reliability. With a drum you have cable stretch, brake dust buildup, and a variety of factors that make the stopping experience different every time you pull the lever. With a hydraulic disc setup, you have a lot more consistency.
Maintenance Matters Most
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #9 on: January 10, 2008, 10:32:19 AM »
Or if you're drowning in money you could just call these guys...
http://www.discovolantemoto.co.uk/showpage.do?page=Brakes
–Captain Horatio Hornblower
www.thehairynickel.com
Offline Kevin400F
« Reply #10 on: January 10, 2008, 03:52:17 PM »
On my track bike, I used the 2LS front drum from a DOHC CB450.  I believe it is slightly larger than the CB350/CB360 drum.  Works fine.
Offline pablo78cb550
  • mmmph.
« Reply #11 on: January 10, 2008, 03:58:12 PM »
just go out and get yourself one of these.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline yd72
« Reply #12 on: January 10, 2008, 05:32:34 PM »
Hi all, thanks for all the replys, suggests pls come in.
I have own the bike for 7 years, so I was thinking of going for something different and vintage kind of look. I know disc and drum have its pros and cons. In my country we dont have much resources in either vintage or classic bikes, you dont see many classic bikes here. Finding parts here is an impossible task.
I need more suggests and sources. Keep coming man.........
Offline nippon
    • Classic Cycle City
« Reply #13 on: January 10, 2008, 11:59:50 PM »
Is ebay not available where you are living?  ;)
« Last Edit: January 11, 2008, 12:01:24 AM by nippon »
  • mmmph.
« Reply #14 on: January 11, 2008, 12:35:56 AM »
I drove two hours to get that little '78 red devil.
5700 miles on the clock
and clean.
There are always things around you, relatively speaking.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha XS400
1978 Honda CB550K
Sold off:
1992 Yamaha FZR600
Offline Buber
  • A bit of spanner spinner, but definitely not a
  • #820 on old mailing list.... :)
    • Mountain Chalets in Polands
Welcome to my mountains!
Mountain Chalets
