Author Topic: Is it possable to upgrade the stopping performance of the stock single disk?  (Read 6144 times)
Offline DarkRider
Alright i have been doing some thinking as to the direction i really wanna take with my CB550 project and i realized i wanted to keep the stock spoke wheels..however im still on the fence about the dual disk upgrade..not saying i wont go that route later on just not sure if i want to deal with it now with all the bike needs to start with. Now is there a way to upgrade the braking power of the current set up? i have no issues with the idea of changing master cyl or even the caliper and making an adapter plate to use a more modern piece.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline jreich
I retained my single caliper and I have improved the braking a great deal. I can;t do stoppies, but I don;t need to.
1. I replaced the old rubber brake line with a SS line. It expands less so more pressure is available to the caliper.
2. I rebuilt the existing Master cylinder which is real cheap with OEM Honda parts. Over 30 years a lot of gunk builds up in there.
My handle movement to feel the brakes engage went from halfway to about and inch and it gets better the tighter I squeeze.
If you really need Sportbike level braking you could probably rig up a twin piston caliper on a single disc if you have the machining ability and tools. The disc itself  is really massive when you look at it.
Drilling has pluses and minuses. If your holes are not arrangend properly and theat depends on the nature of the Alloy, you can develop cracks. Drilling can limit squeel a bit and if you are on the brakes a lot dissapate some heat. On the same token you have also reduced the friction area of the disc. Like I said earlier, the disc is real heavy and large, so it would take a lot to make it fade. If you are on the brakes a lot you could fade them. It depends on your riding style.
That is what I did and I am happy with the result.
« Last Edit: February 27, 2008, 06:59:00 PM by BobbyR »
Offline 333
  • Time for change
I'm with Bobby.  Rebuild.  But do the caliper, too.  And if it sees weather the caliper will almost have to be rebuilt yearly.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
6 or 8 piston caliper..bring money..
Offline DarkRider
Thank you for the input guys! its things like this why i love this forum...ask a question and almost guaranteed you are going to get the answers you need. Not looking for sport bike level braking at this point since i have no intentions of doing stoppies and what not on this on this bike. Im just the sort of rider that i will grab the front brake first then apply the rear to bring the machine to a complete stop. As long as the M/C that was listed is compatible with even the stock single piston caliper im happy.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline 736cc
   Sand your discs and pads w/ coarse sandpaper, just like the racers do. Gets rid of glaze and adds bite.
I think you have all of the simple solutions you need to move forward. The SS lines do make a difference. Got mine from HEL USA and they are black sheathed, so they look more original, except they are the diameter of the clutch cable.
Drill your disc too mate, it significantly reduces the unsprung weight, (better handling)allows the disc to run much cooler, (reduces "fade") and helps dissipate water off the discs surface. (pulls you up quicker) If it didn't work, racers wouldn't do it............. Cheers, Terry. ;D
fuzzybutt
i have a 2 pot caliper off of a ninja that i'm going to try and fit to the front of my 750k. i have access to a full machine shop and i'm going to try and machine a spacer to get the width of the caliper to fir the thickness of the stock rotor.
Offline Buber
  • A bit of spanner spinner, but definitely not a
  • #820 on old mailing list.... :)
    • Mountain Chalets in Polands
Having said this Terry, you should add that you CAN'T do it without a help of a shop with big, mutha machines. Them disks aren't made of soft iron.....  ;D
Welcome to my mountains!
Mountain Chalets
Offline DarkRider
Awesome info guys! Just wondering this about the sand paper trick 736..would this work on the rear drum brake as well to clean it up? Will def look into drilling the rotor after the bike is running...(aka after my budget recovers from that stage lol) One of the things im doing to this bike is relacing the stock hubs to lighter 17" aluminum wheels which will allow me to use more modern sport bike rubber (keeping in mind that i go down a speed rating level with the use of tubes in them) so that may or may not help stopping given it would be less weight for the brakes to slow down.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline Buber
Hmm, not being an expert, but.. if you are hoping to see real difference in braking by changing to alu rims... maybe you should reconsider. If you want to feel difference NOW, then braided lines and sintered pads, and that's it. fairly affordable, and really simple to perform.... At least on the front.
Mountain Chalets
Well I do have a shop full of big mutha machines, but you can drill yours discs at home with a cheap drill press and some good sharp drill bits.
I've done plenty, and as long as you clamp the discs well, use slow speeds and a good cutting liquid, (dish washing liquid is the best I've used so far) you'll end up with a professional looking result.
If you look at some other disc drilling threads here you'll see that a couple of guys here have templates on offer for those not blessed with a milling machine and a rotary table. Cheers, Terry. ;D
Offline lordmoonpie
    • Moonpie
The mods I do for racing on all my classic hondas keep the original looks and give you power to do a stoppie extreme - over the bars if you want!
You can keep the same master cylinder  - add braided hoses, EBC HH sintered pads or equivalent and then get a machine shop to drill out the rotor and fit a new cast iron rotor to the original disc carrier.. It's not cheap - about £190 GBP for a 280mm 750 disc but the stopping is single finger action. If you then add an AP Classic racing master cylinder you will have brakes as good if not better than most modern road bikes easy!
In the UK, CAT Security Engineering can do the job beautifully, not sure about USA suppliers but CAT will do it mail order if you send in the original disc.
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline DarkRider
Since you do have some experience with them terry would it be possable to send the disk to you and have you drill it? Also...just wondering if one of your oil cooler kits would work on the 550?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline JZEROE
You guys see any reason why someone who was a candidate for front rotor replacement anyway wouldn't buy this:
http://cgi.ebay.com/ebaymotors/Honda-CB550-CB500T-CB-550-500T-Cross-Drilled-Disc-Rotor_W0QQitemZ160212958669QQcmdZViewItem?hash=item160212958669
Guy has good feedback, seems to do this a lot. But $90 seems a little cheap.
'75 CB400F
'76 CB750K - Project Freebike
Offline Jim F
  • go baby go
Here is my take on up-grades
I am waiting on my RC51 rotors to get here
Those are 6 pot calipers off of E-bay for $50 bucks
the Rotors where $85
« Last Edit: February 29, 2008, 09:30:26 AM by big-jim »
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
I'd be happy to mate, but the shipping would probably kill the deal, this guys work looks good though, and 50 bucks for changeover discs is a good price, 3/8" Cobalt drill bits cost 18 bucks each here, so I wouldn't do them any cheaper. I'm busy bashing Sean Condon's tank this weekend, but I'll start looking at oil coolers again before it gets too warm on your side of the pond, ha ha! Cheers, Terry. ;D
jsaab2748
Is your 550 a k model? the '74-'76 has the same lower cases as the 750
which makes it possible to swap to a 750 caliper, and the wheel is the same also, so you can swap out for the bigger 750 rotor to match. Lower cases have the number 341 stamped on the inside edge of case.
Offline DarkRider
Yes my 550 is a K however it is a 77...so that may just take me out of being able to do that..
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline kayaker43
I was going to suggest the 750 brake too, I have one on my 76. Cast iron does have a better coefficient of friction and faster heat transfer, but it rusts badly.
Offline DarkRider
just wondering if i were to take a stock Interceptor caliper and have a replica of the stock caliper mount made but designed for the Interceptor caliper if that would work or not...guess im just seeing the stock single piston as a possable weak point..
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline DarkRider
wasnt saying that it should increase performance just hoping it may since its reducing the weight of the machine the stock brake system has to bring to a halt lol
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline DarkRider
Ok the RC51 rotors that Big jim is using are they larger then the stock rotor in diameter? If so i will look more into the idea of making a new mount to use one of the 4 pot calipers from the Interceptor parts bike to use a single RC rotor..seems like that may get me just what im seeking
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
