Author Topic: What is this thingy? Bare frame ?  (Read 1606 times)
Offline jdawg
« on: March 01, 2008, 07:13:34 AM »
Hey guys need some help. I got her all stripped down and I'm cutting off the bits i don't need/want. But....  what is the hook shapped do-hickey in the middle of the pic?  ??? I don't remember what it did or what may have been attached to it.
Any one?
1974 CB750 K4 - old junk to fiddle with
Offline Patrick
Re: What is this thingy? Bare frame ?
« Reply #1 on: March 01, 2008, 07:30:47 AM »
Your center stand.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Johnie
« Reply #2 on: March 01, 2008, 07:32:25 AM »
Agreed...looks like the bracket for the center stand pin.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #3 on: March 01, 2008, 07:43:41 AM »
The C shaped stamped thingie goes between the spring & this.
Offline Gregorymoto
  • SOHC Aficionado
« Reply #4 on: March 01, 2008, 08:44:08 AM »
Cut it off
Yep, i have issues with this sort of stuff.
Offline jdawg
« Reply #5 on: March 01, 2008, 04:23:09 PM »
Thanks guys. Consider it gone, cutting wheel in hand (almost).
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #6 on: March 01, 2008, 04:34:47 PM »
You not using a centerstand anymore?  Might as well cut the mounts off as well.
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
76 cb550
« Reply #7 on: March 01, 2008, 08:45:49 PM »
just curious.  Why would you remove your center stand mount.  It would be nice to be able to easily change your mind...or a future owners mind.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #8 on: March 01, 2008, 08:50:43 PM »
That frame looks like its long past anyone changing their mind  ;D  Cut it off!
Just so long as you left the sidestand mount in place of course ;)
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
fuzzybutt
« Reply #9 on: March 01, 2008, 08:55:46 PM »
i'm making a stand off bracket to work with my kerker and putting the one off of my 75 750f onto the 74 750k
Offline plastikjock
« Reply #10 on: March 01, 2008, 11:51:13 PM »
Your rearset mounts look great, Is that a solid machined piece at the end with a clearance hole for the rearset bolt to go straight through? I am currently working out that bit, I'm thinking smaller tube (approx 1/2") in a triangle like yours. Then swaged down at the end and welded to some 1/4" plate. Much like the rear dropouts on a pushbike.
Offline jdawg
« Reply #11 on: March 02, 2008, 05:28:19 AM »
tintin - I cut the side stand off too. I have a great sense of balance and I'm hoping my bike does, if not I'll just throw it on the ground like my mountain bike. j/k I did cut the side stand off, cuz it hits the rear sets when it is up. I'll be moving it forward a few inches. Below is a pic of what I do instead of a center stand.
plastikjock - that is a solid piece machined with a counterbore to recess a SHCS from the inside. Here are a few more pics minus the counterbore....
Offline Gregorymoto
  • SOHC Aficionado
« Reply #12 on: March 02, 2008, 11:19:22 AM »
Nice Job man
