Author Topic: Quick fuel line question  (Read 1324 times)
GotRhythm
« on: April 07, 2008, 07:02:57 PM »
Hi all, I'm wondering what's the best setup for connecting the fuel lines to the petcock (I have the one with dual fuel lines). Whenever I go to pull my fuel tank and or carbs it's always a pain in the ass to get those little clips and fuel hoses off it's so tight in there...thx in advance.
Offline my78k
Re: Quick fuel line question
« Reply #1 on: April 07, 2008, 07:07:45 PM »
I never used the clips....I stuck to tie wraps. Sure, ya gotta replace em when you cut the off but it was a heck of alot easier!
Dennis
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #2 on: April 07, 2008, 07:15:26 PM »
You can use small hose clamps in place of the clips too... ;)
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #3 on: April 07, 2008, 07:32:37 PM »
I clamp the carb end, but leave the petcock end unclamped.  I've never had a problem.  I also replace the fuel lines every 2 years, so they tend to stay supple.  Motion Pro clear line works best and my local M/C shop stocks it!  Quarter-inch on the float bowl drains and 3/8 on the petcock.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline MrZxp
« Reply #4 on: April 07, 2008, 09:56:02 PM »
Ditto. My 550 has been this way for the past 22 years with no problems!   :P
Cheers, Phil
09 Boulevard M90
SOHC4 Member #3336
