This is the usual sequence for removal:
-Unscrew the the four clutch pressure plate mounting bolts, and remove clutch pressure plate and springs.
-Remove clutch lifter piece
-Remove snap ring, shims (if any) and clutch assembly from main shaft (Your clutch may not have a snap ring, instead it may have a lock nut and tongued washer and spring washer)
-Disassemble the clutch discs, plates, and clutch centre from the clutch outer
This is the usual sequence of assembly:
-Install the clutch outer to the mainshaft and then install the clutch centre
Assemble the oiled friction discs and clutch plates on the clutch center, and then, assemble into the clutch outer. Make sure the grooves are facing /// when looking at top left of clutch assembly. i.e. if the shaft were rotated counterclockwise the inside end of each grove should proceed the outer end of each groove going into the turn. As per my note to zeus87 - reverse to what he has in his photo
-after all the discs are assembled, put shims and the snap ring onto the main shaft (On your clutch it may be tongued washer, then spring washer , then lock nut)
If you have a lock nut, then shims are not required.
