Author Topic: cb750 carb holders  (Read 3158 times)
splittie
cb750 carb holders
« on: May 14, 2008, 01:33:00 PM »
I just bought my first cb750 and the PO had cut the carb holders/tubes off. These are the tubes that go from the carbs to the engine.
My question is this, is there any adhesive that I could use to do a temp. repair on these tubes??
I am thinking something that would work similar to testors plastic modeling glue. I remember using that stuff on plastic models and it would basically melt and bond the two pieces of plastic together.
This is just a temp fix to see if I can get the bike turned over without having to tear down the carbs and redo the gaskets etc.
And only the outer two have been cut (One is cut in two and the other is cut @ half way through)
Any advice/ help would be great.
Offline mystic_1
  • 1970 CB750K
Re: cb750 carb holders
« Reply #1 on: May 14, 2008, 02:16:12 PM »
I don't think that any adhesive will cure that damage.  The carb boots are exposed to heat, gas, and vibration.  You could probably rig up something out of radiator hose or the like, just to see if the bike will fire, but you'd probably be best of finding some used ones on eBay or something.
mystic_1
- John Augustus Shedd
splittie
« Reply #2 on: May 14, 2008, 02:22:26 PM »
I was going to this as my second chioce. ;)
I figure I should be able to find something close to the size.
Thanks for the input
Offline Gregorymoto
  • SOHC Aficionado
« Reply #3 on: May 18, 2008, 01:56:08 PM »
I will say this, buy new ones, or used ones on ebay.
Rigging this is hard and will take allot of time, and more than likely will not work out well.
Trust me i tried this 15 or so years ago.
Yep, i have issues with this sort of stuff.
fuzzybutt
« Reply #4 on: May 18, 2008, 05:37:42 PM »
got a set of new ones for my 74' 750k for 69 dollars plus 7.95 shipping
« Reply #5 on: May 18, 2008, 05:55:12 PM »
You can buy them new from Honda for the same price as ebay and you are sure they are new supple.
Offline UnCrash
  • Pass
    • My Blog
« Reply #6 on: May 19, 2008, 06:55:14 AM »
I just bought a set from Z1enterprises.com.  They're members here and really have great customer service.
If you're going to keep the bike and fix it up you might as well purchase new ones.  Never purchase used ones unless they're nearly free.  Old ones get hard and cause air leaks which can impair and even hurt your engine.
Yours were probably so hard and worn the PO just cut them off knowing they would need to be replaced.
splittie
« Reply #7 on: May 19, 2008, 02:37:33 PM »
I will check Z1 out, I purchased other stuff from them and had no problems.
I'm just impatient and wanted to hear this bike run.
« Reply #8 on: May 19, 2008, 05:39:19 PM »
If you just want to hear it run till the new ones come in, people have used radaitor hose. Very short term.
splittie
« Reply #9 on: May 19, 2008, 09:51:57 PM »
[/quote]
Thats one thing I was thinking of.
I wanna see if I am going to have to do any carb rebuilding etc. before I order the boots.(Save on shipping)
