Author Topic: Repairing riveted petcocks  (Read 17324 times)
Offline Jay B
« on: May 16, 2008, 05:15:34 AM »
My brothers dohc 750 started leaking around the petcock handle. I resurected it for him after being stored for 20 years. It has the same non servicable riveted petcock as the newer sohc's. I found a new valve seal on eBay for $8 including shipping. The ears that the rivets go into on the valve body are made such that you can drill straight through them. Went to the hardware store and found the smallest machine screws and nuts I could find and a bit to match. I drilled off the rivet head and removed the faceplate and internals. Then I drilled through the ears on the body and put it back together with the nuts on the back side. Worked great and now it's servicable in case it ever needs freshening up again.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline Jay B
Re: Repairing riveted petcocks
« Reply #1 on: May 16, 2008, 05:18:16 AM »
BTW, if anyone wants to try this, search eBay for "honda fuel valve". For some reason the seller doesn't mention petcock in description and it wont come up searching petcock. He says the seal is "about 20mm" That's the one.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline 750essess
  • Orleans Cycle Repair & Resto
« Reply #2 on: May 27, 2008, 11:50:32 AM »
I did the same thing to my 79cb750, 'cept I tapped the holes. Those petcocks are stupid expensive, and your trick is a great way to save one
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
« Reply #3 on: June 03, 2008, 04:52:54 PM »
A real old school trick is to remove the seal and turn it over. The back is smooth and unworn.
gasshog2
« Reply #4 on: September 02, 2008, 06:42:59 PM »
Since it was a non servicable riveted petcock how did you know what valve seal would work?  I have a 1978 750K and it leaks when going from OFF to ON and ON to OFF.  Would love to know which valve seal to buy.  Thanks
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
« Reply #5 on: September 02, 2008, 08:49:22 PM »
+1
Thanks,
Jona
Found real friends here !!!
« Reply #6 on: September 02, 2008, 11:01:07 PM »
I rebuilt my 78 Cb750F petcock, drilled the "rivet" and tapped the housing and used this gasket.  One done one to go.
Offline cb750k7
« Reply #7 on: September 09, 2008, 08:51:09 PM »
Hi,
Is it the gasket to be replaced?
TNX
Jona
« Reply #8 on: September 09, 2008, 10:07:57 PM »
yes
gasshog2
« Reply #9 on: September 13, 2008, 03:44:53 PM »
Today I decided it was time to attempt to repair my 1978 750K's leaky petcock.  The face plate is not actually riveted on.  The body is casted with bosses that acts as rivet to hold the face plate on.  I removed the head of the so called rivet using a large drill bit turning it by hand.  I removed just enough of the head to get the face plate off. Then with a file I cleaned them up so the face plate would fit over them with ease.  Now for the tricky part,  you better use a drill dress, I drilled #36 holes through the center of the bosses (no room for error here, very little edge margin).  I drilled them approx. 3/8" deep.  Tapped the holes using a 6-32 tap.  Pickup (2) 1/4 long 6-32 SS pan head screws and using  the Honda OEM gasket 16955-268-020 as suggested by TWOTIRED I reassembled all the parts.  Works great..... Thanks to TWOTIRED....
ev0lution7
« Reply #10 on: September 23, 2008, 12:09:30 PM »
i did mine this way as well works great! i just took my time with the tap and it work! i'm realy happy to have a rebuildable petcock now! specially if you look around on ebay and find only NEW petcocks for $50+ way nice for about $10 fix!
Offline sohc4Lat
« Reply #11 on: May 04, 2011, 04:19:01 PM »
Thanks Lloyd, et al! My petcock was not leaking and all three functions still worked, but she would cut out or hit a flat spot with no recovery or rpm climb in 5th. Must have been sucking air into the fuel delivery. All that is history now! Thanks for the heads up, folks!
Too bad I didn't get her fixed before I rode her from Dallas to Houston this last weekend, but that is a whole nother story! She got me there and back. Yep, now I am bragging!!! The '05 BMW GS was taking  a dead battery nap! ~Jeff
Offline rocketritch
« Reply #12 on: March 06, 2012, 04:46:39 PM »
Anyone know if this gasket will work for a 1982 Nighthawk 750?
Offline DWS
  • Treat others as you would like to be treated .
« Reply #13 on: September 28, 2012, 01:15:50 PM »
thanks for the tip. i need to do this now, i was going to drill out the rivets cause that was the only thing i could do next without buying a new one but now i can buy the seal that i need. thanks
Always looking for friends.
78CB750F3
PD 42A with original breadbox
4 into 1
valves adjusted to .003 (intake and exhaust) ( as was suggested for cooling )
slow jets#35 Main #110
 turned out to 1.5 some paper work says 1.75
4800 feet altitude
78 Honda CB 750 F3 Restoring now(Almost done)
BSA MX 50 Next
BSA b50T Parts
« Reply #14 on: September 28, 2012, 01:32:17 PM »
While doing refurbish on the GL1100, I found these petcock repair gaskets made in Viton rather than the rubber Honda uses.  Rubber was fine for non-ethanol gas.  But, elected officials/agencies removed that choice for many of us.  Viton withstands ethanol.
http://www.randakks.com/Carb%20Parts.htm#13A
GL1000 / GL1100 Petcock Repair Kit
    Item # GLPETRK01
http://www.randakks.com/Petcock1.jpg
They are $16.  But, I know of nowhere else to get them in Viton.
Offline DWS
« Reply #15 on: September 28, 2012, 01:55:13 PM »
thanks do myou have any idea where to get  parts for my cb750 1978 f3 PD42A carbs. some doc saids its suppose to be PD42b and there not whats up with that? bought the bike new in 1978
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
« Reply #16 on: September 28, 2012, 02:23:24 PM »
What parts?
Have you tried sirius?  There are parts suppliers listed in the FAQ.
This chart says you have the correct carbs on your bike:
http://www.motorcycleproject.com/motorcycle/text/specs.html
Offline DWS
« Reply #17 on: September 28, 2012, 06:20:48 PM »
thank you for the chart (TwoTired ) one of the PDF files i down loaded said it should have been PD42A but now i feel better that you showed me the deference. the jets in the carb is 110 though
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
