Author Topic: $5600 per run!  (Read 1085 times)
Offline sparty
  • I just play one on TV
    • Gallery
$5600 per run!
« on: May 17, 2008, 08:54:17 PM »
I watched the NHRA Thunder Valley Nationals at Bristol this evening.  They were doing a segment on the costs involved in Top Fuel racing.
To be competitive:
10 million to run the car for the NHRA season plus
1 million to pay the crew
1 million for transportation and lodging
Each trip down the 1/4 mile costs on average $5600.
A Formula 1 race team's yearly budget is around 250 million Euros per car.  But starting on 2009 it will be capped to around 175 million Euros.  Which doesn't include salaries.
Moto GP budgets average around $40 million for a season.  Excluding salaries.
NASCAR budgets are around $100 million for each car.
The quote of the day came from Warren Johnson, "These cars don't run on fuel, they run on MONEY"
Sparty
1972 CB750 K2 Cafe' Style
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: $5600 per run!
« Reply #1 on: May 18, 2008, 07:30:55 AM »
I thought that they ran on the race track.......sorry. ::)
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Re: $5600 per run!
« Reply #2 on: May 18, 2008, 09:30:10 AM »
Probably at least 10 gals fuel per 1/4 mile..
motor only turns over a couple hundred times during the run..
Pistons get changed daily otr throughout the day, they check em later, some need the ring grooves remachined as they squish down..
Re: $5600 per run!
« Reply #3 on: May 18, 2008, 08:18:04 PM »
Sparty,
Thats about 1 run for your engine isn't it?!  ;)
How's that #$%*kicker doing? Any timeline on the dyno?
Offline toycollector10
Re: $5600 per run!
« Reply #4 on: May 19, 2008, 01:06:58 AM »
A lesson in acceleration:
First, some useful info:
* One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500.
* Under full throttle, a Top Fuel dragster engine consumes 1½ gallons of nitro methane per second; a fully loaded Boeing 747 consumes jet fuel at the same rate with 25% less energy being produced.
* A stock Dodge 426 Hemi V8 engine cannot
produce enough power to drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the
supercharger on overdrive,the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for
nitro methane the flame front temperature measures 7050 degrees F.
* Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug.This is the output of an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. Cutting the fuel flow can only shut down the engine
* If spark momentarily fails early in the run,unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
*In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. In order to reach 200 mph well before half-track, the launch acceleration approaches 8G's.
* Dragsters reach over 300 miles per hour before you have completed reading this sentence.
* Top Fuel Engines turn approximately 540 revolutions from light to light!
* Including the burnout the engine must only survive 900 revolutions under load.
* The redline is actually quite high at 9500 rpm.
* The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second. The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00 mph (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta).
Putting all of this into perspective:
You are riding the average US$250,000 Honda MotoGP bike.  Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the RC211V hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph (293 ft/sec). The 'tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your wrist cranked hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it! From a standing start, the dragster had spotted you 200 mph and not only caught you, but nearly blasted you off the road when he passed you within a mere 1320 foot long race course.
That, folks, is acceleration
1969  CB 750 K0
1973  CB175
1973  Z1 Kawasaki
Offline tramp
Re: $5600 per run!
« Reply #5 on: May 19, 2008, 03:49:28 AM »
back in 76 at orange county speedway they had 36 funnycars line up before the grandstands and fired them up at once
i still remember the noise and vibration in my face
it was great
1974 750k
