Author Topic: have to run at half choke at all times???  (Read 1824 times)
boknox
« on: May 23, 2008, 05:35:01 AM »
Ok. I have another ? 74 cb550, sat for who knows how long, pulled carbs cleaned and did carb kit. Here is where i don't get it. put carbs on without airbox had to run at half choke but ran very well. hooked airbox back up and still have to run with half choke. Runs well at half choke still. Any ideas? If it isn't going to matter if the airbox is on or not i may go with pod filters. Again thanks in advance.
uptworedline
Re: have to run at half choke at all times???
« Reply #1 on: May 23, 2008, 05:37:10 AM »
def sounds like your bike isn't getting enough fuel to the cylinders. richen up your mixture about 1/4 to 1/2 turns on each carb. make sure all the carbs are at the same screw setting.
Offline kghost
« Reply #2 on: May 23, 2008, 07:06:14 AM »
Sounds like you missed something and still have a jet clogged.
I know..now your shaking your head and saying no way brother them suckers were clean as a whistle....
If its any consolation I had exactly the same problem on a 400...I would have sworn on a stack of bibles the carbs were clean.
I aint exactly a rookie either...I have 7 SOHC's of various displacement and years...
Done countless carb cleanings over the years....
But I missed a piece of trash and sure as Christ made little apples....half choke.
Number 4 jet had a piece of trash when I took them back apart.....
It happens.... ::)
Stranger in a strange land
Offline spdiii
« Reply #3 on: May 23, 2008, 08:01:55 AM »
Newbie chiming in. Assuming all your adjustments are correct and the carbs have been thoroughly cleaned, one question come to mind. Are the replacement jets in your rebuild kit identical to the ones removed, (if any)
Nick
Nick
'73 CB500
'73 CB500 Cafe
'74 CB550
'74 CB360 Bobber
'75 CL360
'76 CJ360 in progress
'99 Speed Triple
Bay City, MI
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: May 23, 2008, 10:40:10 AM »
How's your air filter?
mystic_1
- John Augustus Shedd
Offline 333
  • Time for change
« Reply #5 on: May 23, 2008, 11:35:25 AM »
How are the intake boots?  A leaky one could do that.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
boknox
« Reply #6 on: May 23, 2008, 11:57:44 AM »
Ok i was being dumb. I was thinking i was opening the choke when i was actually closing them. Now I have a different problem. The bike was running great took it for a run after about 5 miles it started to bog and lost power. it would run kind of then take off then bog again. I don't know what is going on.
« Reply #7 on: May 23, 2008, 12:56:06 PM »
Has it had a complete and thorough tune-up in the last 3000 miles/3 months?
Are the spark plug tips black with soot?
Is the battery voltage low?
Online HondaMan
« Reply #8 on: May 23, 2008, 08:47:59 PM »
What he said...
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #9 on: May 23, 2008, 09:04:09 PM »
Is your fuel line straight?  Did you put an in-line filter on it?  I once had a high-speed stumble when warm which I traced to my in-line filter trapping air and restricting flow.
I'd say if your in-tank filter is good, get rid of the in-line.  Keep your fuel line as straight as possible and always on a down slope.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #10 on: May 23, 2008, 09:38:26 PM »
Did you clean your fuel tank before you cleaned your carbs? If you didn't, crap will find its way down into them and bugger up the whole works... ;)
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
boknox
« Reply #11 on: May 28, 2008, 11:04:58 PM »
what is the best route to run the gas line from the tank to the carbs. Right now it has inline filters, (which i will take off) and the lines run from the tank down to the filters on the outside of all of the carbs then back in and then connecting to the carbs. Really ugly looking with the lines and filters showing like that.
« Reply #12 on: May 29, 2008, 04:09:11 PM »
IMHO, if your in-tank filter is good, trust it and ditch the in-lines.  Run the fuel lines however they aesthetically please you, but always on a down slope.  You don't want any high spots that might trap air.
If you feel you really need to have in-line filters, mount them standing on end, say right on top of the carb fuel gallery.  Just make sure the filter itself doesn't become an air trap.
Sure.
Is it hard?
