Author Topic: Wheel Removal  (Read 1026 times)
Offline wildcatmahone
  • Poseur
Wheel Removal
« on: May 23, 2008, 12:32:16 PM »
Hey whatsup all I have some new tires I need to install and would like advice on the removal of the front and rear wheels...
1) What tools should I use to remove the axles?
2) How do I get at the front axle there is some caps holding it in place?
Any help is MUCH appreciated..thx
Offline kghost
Re: Wheel Removal
« Reply #1 on: May 23, 2008, 12:41:50 PM »
Remove the speedo cable.
Use a 14 mm wrench to remove the nuts holding the caps on....
Then the wheel will just fall out.
Stranger in a strange land
Offline smccloud
    • Shaun's blog
Re: Wheel Removal
« Reply #2 on: May 23, 2008, 01:51:17 PM »
rear is easy too, loosen the axle nut, loosen the adjusters, and then take the 12mm bolts out at the end of the swingarm and pull the whole wheel off.  much easier than trying to slide the axle out while the wheel is on the bike like i used to do.
CB750 K2
Quote from: Hush
Who needs a mobility scooter when you've got a SOHC4?
Gun/Cars/Motorcycles/Computers/Insert Next Expensive Hobby here
  • Poseur
Re: Wheel Removal
« Reply #3 on: May 23, 2008, 02:19:51 PM »
Hey thx for the tips....gonna give it a shot tomorrow if the weather holds up. By the way it's a CB750K4...
Anyone have any trouble putting on Bridgestone Spitfires to the stock wheels 90/19" front 130/18" rear?
Cheers Wildcat
« Last Edit: May 23, 2008, 02:23:11 PM by wildcatmahone »
